Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
I have a poulan pro 221 40cc 16" bar and need to know what size chain to pick up for it
dennisgladx
  • 52 Answers
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
  • 211 Answers
SOURCE: interchange smaller bar & chain for existing chain saw
Yes you can(better for the engine).For14" the part number is 52 and for 16" is 60.
savumihai71
Posted on Nov 29, 2008
  • 205 Answers
SOURCE: Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Posted on Apr 28, 2009
  • 82 Answers
SOURCE: What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Posted on Jan 25, 2010
dontbother10
  • 2220 Answers
SOURCE: poulan 221 pro 40cc chainsaw that needs a fuel
A typical fuel system and a couple of tips can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Poulan PP221 Gas Chain Saw Type 4 IPL link (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP221-Gas-Chain-Saw-Type-4/75.PP221-Gas-Chain-Saw-Type-4.1.59.1.html
All fuel components are listed.
If not your saw yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you need additional help or have questions please reply below and I will get back to you. HTH
Lou
Posted on Feb 19, 2010
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cannot get chain back on bar of poulan pro electric chainsaw model 1630
Slide the bar on the studs all the way to the left, or rear of the chainsaw, and feed the chain around the motor sprocket, THEN along the top of the bar to the right, and around the bar's sprocket at the right end of the bar, if this doesn't work, report back. This is the original bar and chain correct?
Nov 21, 2010 | Poulan 1630 16" Chain Saw
Chain won't stay tight on my poulan 222 pro. I have the correct chain size. Does the bar need to be replaced?
No, the bar fasteners are not tight enough. If the saw is under warranty, take it to a servicing dealer for repair or instructions to correct what you are doing wrong. Good luck!
Jul 16, 2010 | Poulan Pro Chain Saw 46cc 20"
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain will not turn
take it back sounds like you have stripped the drive gear
May 25, 2009 | Poulan Pro Chain Saw 46cc 20"
I would like to go down A bar size our two on my poulan wildthing
I have a Poulan Pro 295 20".  When I bought it I also bought a 16"bar and chain and have been using those since.  They make the saw much easier to handle and are a better match to the available power. The key dimension is from the bar's mounting hole to its end.  At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there.  This can be easily seen by laying one bar over the other.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Interchange smaller bar & chain for existing chain saw
savumihai71
Oct 13, 2008 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
194 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
