Hi, i have a samsung v25 laptop and there is a problem with the charging. the power adaptor flickers on and off when it is plugged into the laptop causing it not to charge properly. when it is not connected to the laptop it seems to work fine because the light on the adaptor does not flicker. please advise on what the problem could be. thank you
  • 6,487 Answers
This is a problem with the power adapter that you may need to replace it already since that is causing the laptop not to work properly.
Hope that helps..........
Posted on Aug 14, 2008
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Hi, my Samsung laptop v25 does not hold battery charge. I have replaced the battery with new one but it still does not hold it. thanks for help.
Is it charging? Does it Fully Charge? When you say "not holding a charge", how long are we talking about? Minutes, Hours? Battery life depends on what your doing and what is running and other factors, Some aftermarket batteries aren't very good. Inexpensive batteries are cheap for a reason.
Jan 11, 2013 | Samsung V25 2600XPP (NV25NP0SJM/SUK) PC...
How can i turn on the wireless on samsung v25
well your laptop should stay on when you take it off of your charger if its charged. Usually when someone has the problem it means the battery on their laptop is no good. This usually happens when you let your laptop die and lose all its power from the battery this can really damage your battery. Thats the only thing I can think that happened. Your probably going to need to get a new battery. I hope I helped you.
Dec 15, 2009 | Dell Latitude E5500 Laptop
Need to know how to wire the power socket at back of v25
Have you determined the problem correctly?
The fault maybe the power adapter or the power plug that connects into the laptop's power socket rather than the power socket on the laptop.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. The power socket is soldered directly onto the motherboard, there is no wiring required.
If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | Samsung V25 XVC 2800 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
V25 laptop will not turn on from battery power
The problem associated with Laptop not being able to power from the Battery, even if the Battery is new, can be attribute to the mainboard charging Electronic. The charging electronic in Mainboard is perharps defect. If your laptop still have warranty, this is the best time to change the mainboard.If not, seek for a qualified technician to check the PC, run the system, make Bios Update, and have the mainboard checked.
Nov 08, 2008 | Samsung V25 XVC 2800 Notebook
BATTERY FOR SAMSUNG V25 MODEL NO. NV25NH0VM3/SUK
I ask my frend if they have a battery + charges of your Laptop.
i get already the information.
Aug 10, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 notebook Tft failure
We got your messsage and we're looking.
Jul 01, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
