Question about HP C7438A (Refurbished) DAT Tape Drive
Installed hp c7438a usb drive on Windows 2003 server - tape drive shows in device manager as working properly, but unable to see device as a drive possibility for backups - using Cobian backup software
5 Suggested Answers
Kidyubyub
  • 143 Answers
SOURCE: Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
Posted on May 23, 2008
  • 30 Answers
SOURCE: Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Posted on Jul 24, 2009
  • 74 Answers
SOURCE: Tape Drive Block Size
Bit of an odd one but i agree that block size could cause an issue.
Try this link for the HP tech manual for this drive.
http://www.tag.com/tech%20support/System%20Resources/Drivers%20&%20Utilities/Drivers/Current/7.2/HP%20DAT%20Storage%20Works/guides/unix.pdf
It may help with your issue and does detail block size changes on some systems.
Posted on Aug 24, 2009
SOURCE: Certance Ultrium 2 tape drive
Bet if you check, it is not overwritting the tape (appending) on the first tape, but will overwrite the second. Check the media properties to see. If it is this, it has probably had an update when it started going south....
Same problem here, on with Symantec about it...
Posted on Jan 13, 2010
My Transcend JF V 30 / 256 GB Pen drive not able to format. I want the tool for format the same. I tried with HP formatting tool but unable to complete the format.
GO TO 2003 SERVER MY COMPUTER MANAGE AND DISK MANAGEMENT
RIGHT CLICK ON YOUR PEN DRIVE FORMAT NOW
TO USE HP FORMAT TOOL TO FORMAT YOUR PEN DRIVE
NOTE YOUR WINDO ARE ONLY 2003 SERER AND OTHER SERVER
ENJOY IT
May 17, 2011 | Transcend (589307) Media
Segate 1TB not working with Windows 2003 Server
Is this an internal disk, or an external backup device? Two possible routes:-
Internal disk:-
Ok first thing: Does the BIOS see the drive? If not, try flashing the Server's BIOS to the latest version. Check that the system will support disks >500Gb. Try turning on LBA in the BIOS. It shouldnt affect it, but has been known to.
If its not showing here, its either faulty, dodgy cables, or not supported.
If its visible in the bios, great. Make sure you have at least one and preferably all the service packs installed. Gold (RC) only supports 500Gb drives.
Make sure you have Chipset drivers installed for the mobo. If its visible in the disk management console, then create a small disk, NTFS.
External backup device:-
Either you will need to install the software in 'compatibility mode' for xp, OR
dont use their software at all. Just plug the disk in, and it should appear as a removable device. Then use the windows backup tool to create a backup file on the external disk, and run a backup using that.
Jul 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HP C7438A, tape drive doesnt compress data
Several things might cause this.
1st off is that your drive will only compress if the backup software tells it to - so ensure your software is asking the drive to compress.
There is also a dip switch on the bottom of the drive that will disable compression - i think it it switch 3 on the underside of the drive on the main pcb
Jan 30, 2009 | HP C7438A (Refurbished) DAT Tape Drive
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Cartridges will not stay in & cannot see the device in 2003 enterprise
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Apr 06, 2008 | Iomega REV Tape Drive
/dev/st0: Cannot open: Input/output error
Just the fact that /dev/st0 exists indicates that the OS sees the tape drive. When you say you are "moving the data to tape drive" just how are you doing this? Have you read the dump man page?
Jan 25, 2008 | HP C7438A (Refurbished) DAT Tape Drive
Dec 06, 2007 | HP C7438A (Refurbished) DAT Tape Drive
HP C7438A (Refurbished) DAT Tape Drive Logo
783 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
