Question about Miele W2888WPS
My miele navitronic w2888WPS is leaking from the bottom. What could be the problem?
2 Suggested Answers
  • 1462 Answers
SOURCE: I have a miele w2888wps
i think you maen the outer door clamp - the one that holds seal to cabinet
it just tucks into a groove in the seal with the spring at the bottom
Posted on Sep 11, 2008
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Miele WT945 leaks water from internal drain
Hi
If it is the bottom hose on the condenser box leaking.
This is a vent.
It is most likely the condenser box is blocked with fluff and will require cleaning or replacement. I imagine the appliance is not drying very well if at all
Apr 02, 2010 | Miele WT945 Front Load Washer / Dryer
Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
I have a miele w2888wps washing machine and the wire with the spring attached has come off therubber door seal. I would like to see a diagram that shows where / how it fits back on
Sep 11, 2008 | Miele Washing Machines
Miele g665 sc
i think its daft as well but nearly all dishwashers have this feature. you have a leak somewhere to cause this
Jun 26, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele W2888WPS Logo
62 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
