I have a RobinAir 34600 and it keeps telling me to add refrigerant even when the refrigerant tank is full.
4 Suggested Answers
mhkamran
  • 180 Answers
SOURCE: Robinair 34700z not filling source tank / slow recovery
Please check the following:1# For not filling ISV tank (internal storage vassel) Check tank fill solenois,it's may need to rebuild or replace.2# For not compleet recovery,Check & make sure your machine compressor haveing 13''HG suction.if not then you have to replace new compressor.3# Check 13'' vacuum sensor is working properly.
NOTE:PLEASE CHECK FILTER CAPAICITY,BECAUSE EVERY 68Kg/150Lbs OF REFRIGERANT RECOVERY YOU MUST CHANGE SPIN-ON FILTER.
Posted on Jul 30, 2009
mhkamran
  • 180 Answers
SOURCE: ROBINAIR 34788 NO MANUAL REFILL
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Posted on Jul 14, 2010
mhkamran
  • 180 Answers
SOURCE: "Tank Full! Remove Refrigerant From
You should post your problem with Model number of the machine.
However if your machine model is 34700Z, you can try to do the following :
With power OFF, Open front panel cover and remove refrigerant manually from the ISV tank.Open Liquid hose from the tank,then press tank valve as needed.Hope this will solve your problem
Posted on Dec 18, 2010
DISPLAY READS HIGH PRESSURE UNIT DISABLED
This is a common problem of Robinair 34700Z / 347002K & 347112K series machine. So don't worry just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full, carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify if there is high pressure in the ISV tank. Purge excess air from the tank manually. (Open air purge hose from the ISV tank, then carefully press tank valve as needed to blow out excess pressure from the ISV tank)
After doing all above stapes and your problem still exist then replace air purge solenoid (Air purge solenoid located near the ISV tank and fixed with automatic air purge device). Hope this will solve your problem, if so please vote for it for farther help! Good luck
May 17, 2011 | Robinair Cool Tech 34700Z Recovery,...
High pressure unit disabled on unit
If your machine is one of the bellow Model:- Robinair 34700Z / 347002K & 347112K series. just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full, carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify if there is high pressure in the ISV tank. Purge excess air from the tank manually. (Open air purge hose from the ISV tank, then carefully press tank valve as needed to blow out excess pressure from the ISV tank)
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Dec 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE A 34700Z UNIT AND I WAS RECOVERING AND AFTER A BIT IT STOPPED AND SAID HIGH PRESSURE UNIT DISABLED WHAT COULD BE THE PROBLEM.
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution
Aug 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
My machine says high pressure unit disabled and will not let me advance
May 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Reads high pressure unit dissabled
Feb 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
When unit is turned on a message appears that says "high pressure, unit disabled" how do you fix this problem? the machine doesn't let you do anything.
Aug 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
Jul 30, 2009 | Robinair Cool Tech 34700Z Recovery,...
My robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
