Question about Delta Classic, Single Handle Centerset Lavatory Faucet - 522
How remove plastic cap? - Delta Classic, Single Handle Centerset Lavatory Faucet - 522
    Brigadier General:
  • 3,301 Answers
Take the edge of a sharp knife and pry up on it,, use care not to damage the lip ,, I know its hard , But it can be done, if the lip does get a lil bent or scared, Use a nail sandpaper file to smooth the damaged edge
Posted on May 18, 2011
How do I remove the coolant cap? It seems like there is a plastic stop on the cap and reservoir to prevent it from turning.
hi try pushing down on the cap when turning anticlockwise can b tricky but should work ok
Apr 12, 2015 | 2014 Ford Fiesta
Tip
How to Replace a Distributor Cap in Toyota?
Its a plastic cap and and on its top the sparks wires get connected.A small plastic rotor spins inside the distributor cap, firing each spark plug as it rotates. If the distributor gets faulty there the engine may not perform well. in most cases it has been noticed that only replacing the cap does not helps but with cap the rotors also need to be replaced. The procedure is as follows:--- 1) First of all disconnect the negative battery terminal. 2) Then remove the spark-plug wires . Note:-- Before removing the spark plug wires please note down how and where the wires are connected,then only remove the connections. 3) Then on the distributor there will be a cap.remove that cap.the cap is connected by two pins.you will have to press the pins from each side to loosen the distributor cap.Then lift the distributor cap from the top. 4)Then remove the rotor From distributor The rotor is fitted with two screws.Remove the screws and loosen the rotor. 5) Then lift the rotor out from its shaft. 6) To install new rotor and cap.reverse the procedure. This will help.Thanks.
on Mar 25, 2010 | Toyota Corolla Cars & Trucks
How do I remove the plastic cover over the engine on a 3.4 liter 2005 equinox
where the engine oil filter cap, where engine oil is added, if you remove the cap with a quarter turn ccw the plastic pipe that the cap screws into is removed exactly the same way as the fill cap. meaning this pipe is just a 4 inch extension, as if the plastic cover is removed you could throw the plastic tube away and install the oil fill cap directly into the valve cover. once the tube is twisted counter clockwise 90 degrees and lifted up, the plastic cover is able to be removed. when replacing the cover, there is a pin on backside that the cover goes into to keep it from rattling. and dont lose the rubber off the pin on plastic cover as it will rattle and drive you up the wall
Sep 10, 2014 | Metra 40-cr10 2005-2008 Chevy Equinox Ls...
How to change a spark plug
remove the plastic caps. remove the spark plugs using a socket. unscrew the sockets. replace socket. screw it back in. replace plastic cap. move on to number 2.
Jan 16, 2013 | 2004 Ford Ranger
How do i find the cabin filter
Locate the circular plastic cap or caps onthe passenger-side plastic piece just below where your windshield wipers rest.You can best see these when the hood is down Then, Open the hood. Remove the cap or capsby prying them off with a flathead screwdriver. Take out the screw or screws you have uncovered by removing the plasticcap or caps. Set them aside in a safe place. Unscrew Phillips screws holdingthe molded plastic piece down on the inside of the car. Pull up gently on themolded plastic piece to reveal the cabin air filter..
Jan 23, 2011 | 2005 Ford Fusion
How do i get the wire hub cap off in order to access the lug nuts? And i'm not sure what this green plastic t-handle does.
The plastic tool you have removes the hub cap. There is a metal end on the one side of the tool to remove the center cap. Pry it off. Then the tool will fit in to the plastic nut that holds the hub cap on.
Jul 25, 2010 | 1997 Buick LeSabre
How to take off the Windshield Wipers Arm on a Saturn Ion
At the end of the wiper arm where it attaches there will be a plastic cap over a nut.Remove the plastic cap and remove the nut and you will be able to remove the wiper arm.I hope this helped.
Feb 05, 2010 | 2004 Saturn ION
Altec Lansing IMT702
http://www.youtube.com/watch?v=ztxvAAKhwU8
May 06, 2009 | Altec Lansing Inmotion-IM600...
Dishwasher will not drain and wash properly
check airgap on sink (chrome cap) remove cap , and remove top of plastic cap and check for clog .
Dec 20, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Delta Classic, Single Handle Centerset Lavatory Faucet - 522 Logo
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
