I just hooked up a new laptop to the Flatron W2600V monitor. All of the desktop icons and everything are way too big. How can I make them smaller?
  • 393 Answers
Change the resolution of your monitor .
Thanks for using FixyYa.
Posted on May 18, 2011
Text, Icons and Bars set at 500% cannot change
Hook up a mouse with a scroll wheel if you have one, hold down the ctrl key on your keyboard then scroll down on the mouse wheel. See if that works. If it's your desktop that is big as well, right click the desktop, click where it says screen resolution and change it to make it smaller. If that doesn't work let me know and we will try something else for you.
May 05, 2014 | Acer Aspire Computers & Internet
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
I have a LG Flatron L1952T. The language was originally in English but somehow changed to Chinese, how do I get it back to English?
Hello.
I did the same trix.
But I came out of it.
Hooked the monitor to the PC (necessary).
Menu, icon to the right (the gear weel).
As default I was on Language.
Up arrow button until English, then Auto/Set button.
bjorn.braathen@edb.com
Jan 03, 2011 | LG Flatron L1952TX Monitor
I have a flatron w2253tq and have "analoge power saving "on. I cannot see the desktop
Is the monitor connected to the computer using a VGA plug (a smaller one, with 15 pins in 3 rows), or a DVI plug (wider one, with flat pins in 2 rows)?
From what you write, your monitor is switched to the analog input (VGA). It doesn't sense any signal on that input and hence goes to power down mode.
You need to go to your monitor's on-screen menu and select the digital input - you should see the picture then.
Jul 02, 2010 | LG 22" FLATRON LCD Monitor
Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
Aug 03, 2009 | Computers & Internet
HP Pavillion e2200 desktop--Vista. I hooked an extension monitor cable on it and everything looks too big. I went to the control panel and there are 2 choices for sizes and set it to the smallest but it...
What is your setting set at, can you list the actual number x number?
With screen resolution the smaller then numbers on the setting, the bigger it will appear on the screen. If you set it to higher numbers you should get the results you are looking for.
Dec 07, 2008 | HP Computers & Internet
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
How do I increase the size of my desktop and remove the blue border?
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Mar 14, 2008 | Samsung 192MP (Silver) 19" LCD Monitor
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
