Question about Siltec Electronic Weighing Digital Bathroom Scale
When I turn it on the numbers start going up and down never settling at 0. I have a Siltec WS1000
  • 4 more comments
  • rrg1 May 18, 2011
    This is not operated on batteries. It is plugged into an AC outlet
  • rrg1 May 18, 2011
  • rrg1 May 18, 2011
    I have a Siltec WS1000 Digital scale. It is plugged into a 110V outlet. When I first turn it on the numbers start running up and down never settling on 0. When I step on the scale it doesn't settle on a number but weighs me 100 lbs less but the numbers never stop rolling
  • rrg1 May 18, 2011
    It doesn't have batteries in it. It is hooked to AC power.
  • rrg1 May 18, 2011
    I have tried unplugging to try to reset to no avail. There is no reset switch or switches of any kind.
  • rrg1 May 19, 2011
    I haven't tried that. I will let you know. Thanks!
    Guru:
  • 479 Answers
Try replacing the battery, this problem sometimes happens when the battery voltage is low
Posted on May 19, 2011
    Genius:
  • 1,400 Answers
Hello
Have you tried replacing the battery? This should recalibrate the scale also.
Posted on May 18, 2011
  • mpcheesman1
    mpcheesman1 May 18, 2011
    Sorry i did not read the full page.No batterys.Try plugging it into another outlet in the house.
    Possible some interference.
    Also check for a reset button on the bottom of the scale.
  • mpcheesman1
    How about the tare function.Hold the tare button down for 3 seconds before getting on the scale.
    Otherwise the only problem would be the load cell is damaged and would need to be replaced.
  • 2,334 Answers
The first and simple step - replace the battery and then reset scales.
  • Arturs Kalnins
    Arturs Kalnins May 18, 2011
    If the scales are not battery operated, go to settings and reset the scales to manufacturers default.
Fazer 1000 when idol RPM 1000,put the head lights on RPM drops below 0 then returns back to 1000, Has anyone got a suggestion as to why? Many thanks Ian R
The alternator kicks in when the lights are turned on. the regulator then reads the battery voltage and adjusts the charging rate and every thing settle down,try adjusting the idle 11 or 12 hundred it may help .
Apr 03, 2017 | Cars & Trucks
Mitisubishi galant starts fine then stalls out why?
could be a number of problems, I.E: Clogged fuel filter, obstruction in the fuel line that settles when turned off, suction of fuel pump when running plugs the line, bad ignition coil that cuts out when warm. bad fuel pump/ sending unit. or as simple as the vehicles computer kills the engine because it doesn't register enough oil pressure, coolant, or even tranny fluid. just start with checking fluids than check fuel filter, and go on down the list. sorry I couldn't be more specific but without hearing/ seeing the problem, I don't have enough information to rule anything out.
Mar 23, 2015 | Cars & Trucks
Vx 570 auto settlementIf I manually settle my VeriFone credit card terminal in the morning, why doesn't it auto settle at the scheduled time that night?
the terminal is set internally to settle each day on it's own. you can have this turned off if you don't like the feature.
if you select the 0 key or press enter if 0 does not take you to configuration menu. enter your default password or 1 alpha alpha ( key is above the 2)66831 enter, then select the purple more key until you see merchant id.
select merchant id. then press next until you see auto settle time, press select when you see auto settle time. remove the time using backspace key, select exit and save changes red x to main screen. the auto settle should be removed now. but if you do a download you will lose this information so it is best to contact your processor to have your file updated.
May 19, 2014 | VeriFone Retail Supplies
The copy has areas of very light
turn copier off
hold down 0 & 5 while turning it on
then wait then unplug socket developer unit , then press 205 then press start then figure increase by number keys then press start then press intrrupt hope m/c repair
then 0 and set
Sep 20, 2012 | Toshiba Estudio 200L Copier
Error c 440
turn the machine off from the power switch holding down the 0 and the 8 keys and power up the machine when the machines starts enter code 400 and press start. you will see a number write it down. press 0 and press the enter at the bottom of the screen.
turn the machine off and back on normally. if the code returns post the number you wrote down earlier here.
Jul 29, 2011 | Toshiba e-Studio 350 Copier
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
You should get output somewhat like: Default Gateway .... 192.168.123.456
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I CANT OPEN MY SENTRY FIRE-SAFE MODEL:DS3431 SAFE. I KEEP TRYING TO DO WHAT THEY SAY DO TURN DIAL TO ZERO, TURN KEY ETC; NUTHING IS WORKING. CAN U HELP?
Make sure that the key barrel is all the way out. Then replace this example code with your factory code and try it
Example combination: 70-55-05
  1. Do two rotations to the left stopping at 0.
  1. Do two rotations to the left (Anti-clockwise) on the third time past 0 go to your first number.
So – 0 to 0, 0 to 0, 0 to 70
  1. Do one rotation to the right (clockwise) on the second time round stop at your second number.
So – 70 to 70, 70 to 55
  1. Turn directly from your second number to your third number heading to the left.
So – 55 to 05
  1. Push down the handle.
Dec 13, 2009 | Sentry Fireproof Safe
Scale does not work anymore. Batteries are still good
and same again. batteries are fine but i get an error message
pete scarborough qld
Feb 11, 2009 | Siltec Glass Bathroom Scale
Siltec Electronic Weighing Digital Bathroom Scale Logo
154 people viewed this question
Top Siltec Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Siltec Health and Beauty Expert? Answer questions, earn points and help others
