Question about Linksys WRT54GC Wireless Router
I have a WRT54GC Router, it was working good, but started to work bad. When I plug the power cable, all LED light and the power LED turns orange.
Have you tried hitting the reset button with a paperclip? That will reset the router to it's default factory settings after that follow the directions for first time setup
Posted on May 18, 2011
Where do i find NAT settings on my Linksys WRT54GC router? need to get an open NAT.
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Dec 26, 2010 | Linksys WRT54GC Compact Wireless-G...
The Power LED is flashing
If your router is showing this issues, you need to check if the power surge you are using is sustaining appropriate level of power to your router. You can try use a different power surge, a different phone socket or make sure that the power cable is properly connected.If in case this wont work, check if your router is still in warranty so you can ask the manufacturer for replacement of the device.Power light is the indicator if your router is faulty or not. Power light should always be stable green lights.
Thanks for choosing www.fixya.com
Nov 28, 2010 | Linksys WRT54GC Compact Wireless-G...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
WRT54GC linksys wireless router- suddenly all lights are flashing constantly and it does not work
Reset the router for 30 second.
There is a reset button on the router. For WRT54GC the reset button might be at the bottom of the router. There is a flap that you need to turn around. You will see a small reset button. Press it and hold it down for 30 seconds.
release the button. wait for 1 minute. unplug the power to the router and plug it back in.
wait for 1 minute and see if poer light becomes solid.
If not then try to reset the router again.
if the power light is solid then it is in working condition.
Once you reset the router it will come back to the factory default settings.
You will need to reconfigure the router for Internet connection.
If the pwer light is not solid and keep on flashing then it is not in working condition.
If your router is in warranty period then contact the manufacturer and get it replaced.
Click here for more information about router set up.
May 02, 2010 | Linksys Wireless-G WRT54G Router
I have a wrt54gc. It's been working well for some
1. Check with the ISP to see if there are no outages in the area.
2. 1st try to release/ renew the ip.
3. G to the Command line see if you can ping out i.e ping www.yahoo.com or some familiar site.
Apr 26, 2010 | Linksys (WRT54GC) Router
My Linksys wrt54gc quit working. I get amber
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Linksys WRT54GC Compact Wireless-G...
When installing my router wrt54GC v2.0 i encounter
More than likely you have a bad cable. Check or replace the cables. Its very common to have a bad connector on one or both ends.
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
The device is not working. When I conect the power, power led is off and wireless led is fixed green. Sometimes, when I reset the router, the power led turns orange, and the otrers ligths off.
This is a sign of a bad router already, so if its still under warranty you can go have this unit replace from Linksys , since this is already a hardware problem...
Aug 14, 2009 | Linksys WRT54GC Wireless Router
My Linksys WRT54GC suddenly stopped working. The router has no power light but the wireless and internet light are green.
Sounds like a PSU failure possibly.
If you can still get wired internet then its not dead. Its even possible the power LED is pooched if you can still use the wired connections.
Aug 11, 2009 | Linksys (WRT54GC) Router
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Linksys WRT54GC Wireless Router Logo
282 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
