Question about Xerox Phaser 7400/DXF Laser Printer
XEROX Phaser 7400 says output tray full.I don`t understand how I can fix this..where is the output tray?
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Posted on Nov 02, 2009
  • 110 Answers
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Posted on Dec 17, 2009
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
7400 output tray full
That most likely would be a broken paper exit actuator.
May 07, 2014 | Xerox Phaser 7400DN Laser Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
We have a Xerox Phaser 7400. The output is dirty along the bottom 1/2 inch of the page.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to loose toner residue underneath the cartridge. if not then the fuser area has to be cleaned. Wipe the area clean with a lint free cloth, do not use compressed air.....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 04, 2011 | Xerox Phaser 7400/DXF Laser Printer
Getter "Report fault 917" on my Phaser 7400. How can I fix?
I am getting a report fault 917 error on the phaser 7400
Sep 23, 2010 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
Feb 03, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
211 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
