Question about Microwave Ovens
Washing machine not finishing program on any . washing machine is beko wm51205
WASHING MACHINE FINISHES 8 MINUITES FROM THE END OF THE PROGRAM WHAT CAN I DO
Posted on May 23, 2013
Neither is mine. Are any lights flashing?
Posted on Jun 02, 2011
I think the problem is the water isnt going in to machine. Although the moter sound like it might be going
If there is no water flows then the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 05, 2011 | Microwave Ovens
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
Runs down to 1 min. then runs forever .I have to shut it off manualy
Possible that the main program controller unit is not shutting down due to the relay being latched ON even after the time is finished.
You need to check if the processor cuts off the relay and still if the relay holds down, If so the relay drive transistor or the relay is faulty.
Also it can be fault of the program processor/timer as it fails to cut off the relay drive. If so check the circuit, wash the board if you find insects secretion. Also try to solder the processor and associated circuits and try again before the board is confirmed as a suspect.
take estimate and decide.
Jul 12, 2011 | Microwave Ovens
My beko wm6123s is washing and spining but is making very loaud nosies please can you tell me the prom and how to fix it?
It the fault is only about noise then it is important that you need to get a good look at the moving parts when the machine works.
Once you have some idea of the area of noise then shut down and remove the mains plug. Now manually turn the washer drum or the motor to confirm the place of noise. It can be poor bearings, displacement of the drum rubbling against the washer body or even faulty motor bearings.
Sometimes a drop of oil or grease ont he moving part will remove the noise.
Jun 06, 2011 | Microwave Ovens
Not filling up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 16, 2011 | Microwave Ovens
Our beko dwd540w doesnt wash properly every wash the plates and cups ect have bits on them
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe the pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 28, 2011 | Whirlpool Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
