Question about Garden
OLEO MAC TRACTOR WITH KAWASAKI 15HP ENGINE. Cuts out/stalls when ignition switch is turned to Normal, but OK when turned to Caution Reverse Cutting. Is there a difference in the switch positions?
This is nothing to do with what the other lot have said. i work at a lawnmower shop and to me it sounds lik ur neutral posistion sensor. it seems like it is registering it in reverse all the time, hence it only works when u put it to reverse cutting mode. if you want, i am not too far away from you. we are the other side of preston in burscough. give me a ring on 01704 894457.
Josh
Posted on Jul 07, 2011
1995 KLE500 Kawasaki: neutral blue light doesn't show and when clutch is released to engage in gear, engine cuts off
Hi, Ishmael the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Kawasaki KLE 500 dies when clutch is released
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/66113-gears-wont-engage.html
Kawasaki KLE500 Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/searchOM.php?view_lang=EN&spec=OC&
Apr 11, 2017 | kawasaki KLE 500 Motorcycles
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
Kawasaki Ninja Owners Manuals
Apr 01, 2017 | 2008 kawasaki Ninja 650R
Stalls when I push the pedal in reverse, going forward no issues
Hi Dan:
Some of these tractors have a safety interlock on the ignition/start switch that prevents you going in reverse when the mower is engaged.
Check the switch to see if there is a position one click to the left.
If there is, give it a try.
Jun 17, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
My zx7r, ive got no Ignition or Neutral light, I have replaced the ignitor unit,the clutch switch, the battery,the side stand switch,the junction box, the fuel pump and still no ignition? I took off my...
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
http://www.zxforums.com/forums/zx-7r-forum/50874-zx7r-won-t-start.html
my bike will not start zx7r
KAWASAKI NINJA ZX 7R Service Manual
Apr 04, 2017 | kawasaki Ninja Zx7r Zx9r '94 To '04
2002 Kawasaki ZX-6R is stalling when the clutch is disengaged
Hi, Jesse the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike stalls when clutch is disengaged
zx6r 05 when put in gear engine stalls
Kawasaki 2000 Ninja ZX 6R Service Manual
Nov 03, 2017 | 2002 kawasaki ZX-6R
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Tractor stalls when letting out clutch
Sounds like the clutch safety switch is going bad.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stalls when on cutter mode
some mowers have a reverse cut off switch when the deck is down this may be you problem(please rate this) hope this helps.
May 20, 2009 | Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
