Question about Canon Rebel XT / EOS 350D Digital Camera
Rebel XT - damaged ribbon cable from cmos
I am an astrophotographer and wanted to take the infrared filter out of my new camera. The modification went well until I got to re-assembly. I made a small tear in the main ribbon cable from the cmos.  I am looking for suggestions. Can I buy a new ribbon cable? Do I have to buy a new cmos? Can anyone out there do the microsurgery to repair the 2mm tear in the cable? Any help would be greatly appreciated!!!
  • wmyers7737 Aug 18, 2008
    thank you for the suggestion.
    I could solder the connection at the cmos without too much trouble. The connection at the clip end is a different matter. There are approx. 15 connections in the space of about an inch. It is just too small for any standard solder technique. I even tried to used conductive epoxy but by the time you put the epoxy on a single copper strand, it is much to thick, it covers 3 connections. Is it possible to buy a new ribbon cable? I could then de-solder it from the cmos and re-solder the new one.
    Thanks!!
I would suggest soldering a very fine wire jumper cable to bridge the tear. However this is impossible on the ribomn cable itself. You woul have to trace the break to the solderpoint on the back of the sensor. Having said that soldering the jumper at the other end would be the problem as the cable although bare needs to slide into a clip. I did successfully "jumper a ribbon cable on a rebel 300D .. fortunately I was able to locate 2 solder points.
Posted on Aug 18, 2008
Canon EOS Rebel XT with EFS 18-55mm lens. Trouble-free for two years. During a weekend of lots of use, suddenly the camera would not autofocus. Switching to manual focus, the camera worked. Then it...
This sounds like a broken ribbon cable in the lens Take it for repair This type of repair is relatively inexpensive but get a quote as it may be cheaper to replace the lens with a secondhand one.
Apr 03, 2017 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon XT Rebel, I just want to find out if you can see the picture you want to take on the display before taking it?
Sorry, the Rebel XT does not have the live view feature. This is a relatively new development in dSLRs and the XT missed the cutting edge.
Sorry if that wasn't the answer you wanted to see, but there it is.
Sep 09, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT: The upper lcd screen info flickers,some of the icons on the screen work normaly, but other icons are lighter and flicker. Im speaking about the portion that displays battery...
It seems you have a false contact in the upper LCD screen, its flat ribbon cable or the connector at the main board.
It is necessary to open it and check it.
It is fairly easy to do it, but if the camera has a warranty, I do recommend you to make it valid.
If does not have warranty, then you may try in do it yourself if you have some experience and skills to fix electronic devices, or pay to have it done.
Best regards,
Jun 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel only one have of a photo comes up on the screen
Would have to know more of your problem.
It appears like you have either damage to the LCD or internal loose cables. Possibly internal damage could cause this as well.
Jul 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Setting to shoot black and white
No, you can reduce the saturation but not go mono, (in the parameters settings)
You will need to adjust the colour balance and convert to mono in photoshop (or similar)
There are quite a few articles on the web regarding shooting in IR with the rebel, best results can be obtained with a modification to the camera http://ghonis2.ho8.com/rebelmod.html (reversable by using a IR cut filter for non IR shots) as it contains quite a strong IR filter which means although it is possibler without modification exposures will be quite long with IR filters and focusing difficult as the auto wont work and you will be able to see very little trough the viewfinder once the IR filter is on.
Here are a few articles, they may not relate to your exact model but all the eos cameras are somewhat similar.
http://photo.net/equipment/canon/digital_rebel_xt/
http://diglloyd.com/diglloyd/free/Infrared/index.html
http://www.astropix.com/HTML/I_ASTROP/EQ_TESTS/INFRARED.HTM
http://astrosurf.com/~buil/350d/350d.htm
people who will mod the camera for you.
http://www.lifepixel.com/ (also sell replacement sensor filters)
http://spencerscamera.com/default.aspx
Im sure there are many others.
Best of luck
Jun 08, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel xt
I Want a Lastest firmware for 350 D
Jun 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Trouble getting video out to work on canon eos rebel xt
have u changed the PAL or NTSC seting ? u can find it in video system in the last seting menu
Nov 12, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
