Question about Refrigerators
Will not get cold. sounds like the compressor tries to kick on but then clicks and the inside light dims.
  • 1,284 Answers
Hi, i'm afraid this sounds like a compressor problem, the clicking you can hear is the compressor trying to start, but unable to.
Is it accompanied by a dimming of lights?
If so, indicative of a massive volt drop, buy a new refrigerator.
Posted on May 18, 2011
Motor or compressor keeps clicking on and off and will not get cold and the inside light dims when this happens
I would suggest the compressor and or motor are failing. The reason the interior light is dimming when the relay connects the compressor is a larger than normal demand on the power supply, i.e drawing more current (amps) than it was designed to.
Jan 06, 2014 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Relays click when interior fan is on
Often the click which can be heard when the A.C. kicks in is the clutch on the A.C. compressor. Be sure that it isn't just this sound which you are hearing.
Also check the operation of the idle control valve which is supposed to raise the engine revs to compensate for heavy power drain. If this isn't working correctly, then this would explain the lights dimming under low revs.
Nov 16, 2012 | 1998 Ford Escort
The acc fuse in my 2002 ford escape keeps clicking Constantly and at night it dims the head lights each time it clicks. Any suggestions on what might cause this
Fuses don't click. It's probably the relay kicking the compressor on. I would get it checked to see level of freon and how much voltage it's drawing. If thats all ok the compressor may be turning hard pulling more voltage which is dimming lights. If it keeps clicking it sounds like its low on freon.
May 25, 2012 | 2002 Ford Escape
Goodman AC inside handler is running so is outside fan but when compressor tries to kick on (lights dim and you can hear it try to start up) it immediately shuts back off, whats wrong?
It sounds like you need to install what is commonly called a "hard start kit." This is merely a start capacitor that gives your compressor extra punch to get it going. The compressor is trying to start but cannot before it draws too much amperage. A hard start kit should alleviate this problem.
If my answer helped you please take the time to write a short testimonial.
Aug 04, 2011 | Heating & Cooling
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
The Dometic ac.heat pump is not providing cold air. What are the possible causes and fixes? It is about 6 years old.
Could be possible, but normally when a capacitor goes, the compressor will try to kick in momentarily, then back out and when it does, it will draw a lot of current, and likely trip the breaker, or at least draw current down, and make lights in trailer dim momentarily as well. Can you hear a "click" (relay makes that sound) when you go from fan only, to cool on that AC unit ? It almost sounds like a faulty relay, if no current draw when switched to cool. I don't suppose you have a multimeter of any kind?
Aug 06, 2010 | Dometic Rooftop RV Air Conditioner
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Will not cool,will not freeze. compressor will not kick on.
you can try a hard start kit(has a big start capacitor but if it was mine i would replace it)
Aug 13, 2009 | Whirlpool ED5FTGX Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
