Question about E-Machines M5105 Notebook
How to change cmos battery - E-Machines M5105 Notebook
    President:
  • 1,812 Answers
you will get an idea about disassemble for your model ,as well as know better from acer laptop. So click on both the links.
Click on bellow these link for change the cmos battery.
http://www.insidemylaptop.com/take-apart-emachines-250-netbook/
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
Hope this helps. Let me know if you need more informationThanks
Posted on May 18, 2011
  • 313 Answers
It's quite simple. First of all you have to turn off your computer and unplug all device cords from the back. Lay the computer facing up on the floor/table. Now, you have to locate the CMOS battery (It's similar to a watch - a little bigger though). It is on the motherboard held on by thin metal tabs. Some computers have the battery flat against the board while others have it in an upright slot. Use your fingernails to remove the CMOS battery and gently lift the metal tab. It is so weak that it can break easily. Do not lift the tab all the way or pull it off. Take the fingernail and place it under the battery in the casing and easily lift it up then pull it out. The last thing you have to do is replacing the panel and plugging in your devices.
I hope it works! Have a nice day!
Does this P.C have an internal battery, and if so can it be changed
If you mean a BIOS or Backup cell, yes, akk OC's have. We cannot comment on how to do it as you don't reveal the make and model.
Aug 06, 2015 | Computers & Internet
When to change CMOS battery?
You will need to change the battery just when the computer says something like this "System CMOS checksum bad - Default configuration used" or also could say something like "CMOS battery low", etc. That's the time to change the battery.
Jan 26, 2012 | Computers & Internet
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
ASUS Windows 7 laptop cannot keep time! I have checked the bios, and the CMOS battery, and all seems fine. Yesterday it lost 13 MONTHS!! What is wrong?
hi charli, did you change new cmos batter , how you checked your bios cmos battery, if you not changed your cmos battery try to change and check it you may get proper time.
GOOD luck
Dec 31, 2010 | ASUS Computers & Internet
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
CMOS BATTERY ERROR
You said that you already bought a new cmos bat, but still theres a problem.check the cmos battery socket,power on tyour pc and go to cmos setup,optimize default setting and set time and date.
May 27, 2008 | Computers & Internet
Cmos battery?
Computer CMOS information CMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery. Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
Good Luck, Please dont for get to Vote/Thank You
Dec 19, 2007 | HP Pavilion N3390 Notebook
E-Machines M5105 Notebook Logo
402 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
