Question about Nintendo Wii Console
My wii remote wont I guess connect it just keep flashing the lights at the bottom anytime I hit anything on the wii remote or try to sync it
  • 24 Answers
Hold both Sync buttons for a period of 5 seconds, then let go. If this does not work, replug everything on your wii and try again. Make sure your Wii is on when syncing.
Posted on May 19, 2011
My wii remote wont turn on. when I push the on button the four lights at the bottom flash a couple of times then nothing happens and it wont recognise it on our tv...?
Try syncing the wiimote to the wii itself. Underneath the SD card cover on the front of the Wii and inside the battery compartment on the wiimote are red buttons. Hold both of these at the same time for 5-10 seconds and then try again
Apr 13, 2013 | Nintendo Wii Wireless Remote Controller...
Wii remote lights 3 and 4 stay on
The wiimote is busted. Sorry.
Jun 13, 2012 | Nintendo Wii Console
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
Wii remote won't connect to the wii console
Here is what I went through, hopefully it will save you some time.
The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
Apr 18, 2010 | Nintendo Wii Console
The remotes flash then switch off, i have synced them again but still wont work.
start with the basics FRESH BATTERIES:
1) Fresh batteries should be in each.
2) Turn on the Wii with Player 1's remote or the button on the console.
3) Open your SD Card cover and press Sync. Very shortly afterward, press the red button on your P1 Remote (in the battery cover). Lights will blink and then will be showing a light in the first square, denoting the connection is complete and it's P1.
4) Do the same as Step 3 for the P2 remote. For the P2 remote, after the blinking, then the second square will be lit, meaning it's P2.
That is the Standard Connection. It is tied to the Wii until it's re-done.
After you attempt to synch them (pressing the red synch button on the wii, followed by the red synch button underneith the battery cover of the wiimote), make sure the wii is turned on and press the buttons 1 and 2 on the wiimote at the same time to have it search for recognized bluetooth devices (ie. your wii).
_________________________________________________
found this article too.
this should help you.. leave a testimonial if I helped.
If this helped you out, please let me know with a comment below!
Apr 10, 2010 | Nintendo Wii Console
Our new controller wont sync up with our Wii, why? put new batteries in pressed the sync button and the blue lights just keep flashing, is there a special place we have to sit or place the remote?
Did you press the red sync button on the wii where a SD card goes? You press that once then the wii remote sync button once, wait while it flashes then in a few seconds it should be synced in.
Jan 01, 2010 | Mad Catz Video Game Consoles & Games
Wii remotes are not responding to anything. batteries have been changed and lights are flashing but
You need to synchronize them to your Wii. First turn on your Wii. Open the battery compartment on the back of your Wii-mote and the front SD Card door on the front of your Wii. There is a little round red SYNC button on the back of your Wii-mote and a red SYNC button on your Wii in that door. Press the button on the remote and then on the Wii and it should sync. If it doesn't work at first try again. You know it is synched when one of the four LED lights at the bottom of the Wii-mote is solid.
Dec 26, 2009 | Nintendo Wii Console
Wii remote wont work change batteries and all lights at bottom just keep blinking
Sync it.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.If this not help press and hold the red SYNC button on console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync Wii Remote again.
Nov 04, 2009 | Nintendo Wii Console
Wii remotes will not stay on
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Dec 16, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
62 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
