Question about Philips Televison & Video
OUR CRT PHILIPS TV MODEL 21PT3324/71 SUDDENLY STOPS WORKING. NO PICTURE CAN BE VIEWED, NO AUDIO CAN BE HEARED AND NO POWER ON LED LIGHT WHEN PRESSING THE POWER BUTTON EVEN IF IT IS DIRECTLY CONNECTED TO THE POWER OUTLET
SOURCE: I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Posted on Nov 29, 2007
SOURCE: tv won't turn on, power led just flashes
I have the same problem. After about 2 seconds the system status light blinks red and the system needs to be reset. The only way to turn the system on is to unplug from power for 5 minutes and then plug back in, wait for light to stop blinking and then turn on. I have cleaned the filter on the left side. The model is Mitsubishi WD-62725. any ideas?
Posted on Dec 17, 2007
  • 4 Answers
SOURCE: Actually Philips 20PF5320/01 Fault no power, blinking LED
If the TV has sound and no picture, it might be the timer settings. There is a fix for Philips 20PF5320 here
http://www.123datarecovery.co.uk/fix_philips_pf5320.htm
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: No picture and no power LED
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
Posted on Apr 20, 2008
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
Philips plasma TV Model number 42PF7321D/37 with green led light ON but no picture.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 08, 2016 | Philips Televison & Video
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
I bought philips model no. 47pfl7403d/27 in 2008 .Suddenly last month it started skipping picture but we could hear sound.After few days it started smelling like something is burning and it stopped...
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Jun 14, 2011 | Philips 47PFL7403D 47 in. LCD TV
Philips DPTV 60PP9753/17. Problem started when blue CRT seemed to "fuzz" out. Tried to increase the brightness via the Blue G2. Made no difference. The sound quit while the picture was running. Turned...
Hi my name is Roety,
I can help you with your issue ,
First of all lower the blue and any other screen controls or service menu settings back to where they were or lower.
Then see if it powers on again with a picture.
If it still shuts off, unplug the Blue CRT circuit board and see if it works.
If it does work the blue CRT may be shorted .
Your problem may have been corroded CRT pins.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 02, 2009 | Televison & Video
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
Philips 30PW8420/37 TV Won't Turn On
The led code indicates vert failure for one. ( 3 blinks )
The 2 blinks indicates excess beam current of which could be your picture tube or re-adjusting the G2 voltage on the HV transformer which is very critical on philips sets.
Apr 10, 2008 | Philips 30PW8420 TV
Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
I HAD A REPAIR GUY OUT TODAY AND HE SAID IT WAS THE POWER MODULE. I HAVE NOT GOT A PRICE FOR THE PART OR REPAIR YET.
JASONCBFAN
Feb 01, 2008 | Samsung TSL3293HF 32" TV
No picture and beeping sound emitting from unit.
We have had ALOT of samsungs in the shop lately and the most resonable solution for these units is just to replace the controll box as a whole. goto www.vancebaldwin.com and login as guest and search for it by model #.
Sep 15, 2007 | Samsung SlimFit TX-S2783 TV
Dead Philips 32PW9545 TV
the problem is in the power supply or related circuit.call a tech to look at your set.it should not be expensive to fix maybe between $40.00 to $100.00 good luck
Apr 23, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
