Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Washer makes loud humming sound during wash cycle --
  • 1,998 Answers
Loud humming sound as in a jet type of sound? and does it get louder as it goes tto spin usually when it makes this type of sound it means there is a bad bearing between the inner and outter tub most people at this point junk or run the machine till it breaks some do choose to repair it on there own parts are between 120-180 depending on where you buy from a technician charges around 450-600 this is a very time consuming job where it will take the tech 3-5 hours. although without hearing the actual sound can only make an assumption there is a video if you click here to also check if this is the noise that your hearing http://www.youtube.com/watch?v=gSUGbq4GW9w if you have any further questions message me back and please remember to rank how helpful this opinion was when our chat has fully concluded Thanks Rick
Posted on May 18, 2011
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
223 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
