Question about Epson TM-U220 Matrix Printer
Epson TM-U220B printer shows error. Error blinks twice. Pos Systems shows message that it is not communicating with printer
4 Suggested Answers
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
muntejaya
  • 10421 Answers
SOURCE: I have a epson TM-T8III printer of a POS windows 7 printing slow.
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__yhr4e5
Posted on Feb 26, 2011
t_danison
  • 5 Answers
SOURCE: Connection problem with Epson TM-U220B
try holding the button on the interface card and checking your network settings for three seconds and check on how to configure your interface card. That's a start.
Posted on Mar 22, 2013
Printer is not working. Red light blinks once every 4-5 seconds.
An error in the printer is doing this - try Power cycling if not check for consumable status
Jun 26, 2015 | Epson TM-U220B Dot Matrix Printer
check power card connector OR damages
Sep 10, 2012 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Troubleshoot tm u220 printer
CUTTER WIRES
The printers come with a fine wire to the cutter motors, when the cutter engages, sometimes the motor screw is loose and movement of the motor does not help, the movement cuases this weak link to detach or barely detach causing this issue. The blade is in the correct position for this to happen. If the blade is not in the correct position determined by the sensor you will get no action.
Feb 12, 2010 | Epson TM-U220B Dot Matrix Printer
Error light on the printer flashes twice every couple of seconds
check for the event log if it helps you find the reason
Jul 07, 2009 | Epson TM-U220 Matrix Printer
RE: Epson TM-U200 printer with error (2 Flashes)
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
May 27, 2009 | Epson TM-U220 Matrix Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Error LED keeps flashing
your printer needs to be serviced
http://pos.epson.com/service/servASPP.htm
look for a service provider on this website
Feb 20, 2008 | Epson TM-U220PD Matrix Printer
Epson TM-U220 Matrix Printer Logo
138 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
