Question about Watches
I have a Movado Tungsten watch Model 0605850 that I need to re-size the wristband. What tool and how do i push the pins (directions) out and re-size?
  • 2,334 Answers
Search through my tips and tricks. There you will find how to add or remove links.
Posted on May 18, 2011
  • Arturs Kalnins
    Arturs Kalnins May 18, 2011
    For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
I need a value on a men's Movado Watch Model 5895902 89-C1-1432
Look here : http://watchyrtime.com/store/movado_watch_models.html
May 02, 2014 | Watches
Movado 0605781
Based on the picture my guess would be size 3. If I were you I would take that to a local shop. I charge $5 to provide and install spring bars I can't see you getting them for any less than that anyway. Might as well have someone else do it for you.
Nov 28, 2013 | Movado 605638 Watch
Remove watchband from citizen black eagle watch
they will be pins like the ones in this video you will need to push them out with a punch the size of the hole,normal watch bands are spring loaded bars.
Jan 19, 2013 | Watches
How do I remove a steel link from a Movado wristband 800 series?
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Oct 16, 2010 | Movado 800 Performance watch
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    Movado Juro watchband. How to shorten
    mcdevito75 here, Best Bet, look for a small watch repair shop imn your area to svae on cost, special tool available on ebay is needed since it's a Movado let the shop remove links to re size.
    Jun 23, 2010 | Movado Juro 0605024 Wrist Watch
    Shorten movado wristband
    There is nothing you can do yourself as the special equipment is needed.
    Find your nearest watchmaker and ask to shorten your bracelet.
    Dec 18, 2008 | Movado 0605068 Wrist Watch
    Relic Watch Band Removal
    If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
    Mar 04, 2008 | Watches
    Adjusting Band Size on a Movado Amorosa Watch
    there are little pins holding them in place pop them ou and add or delete couple links.
    Feb 10, 2008 | Watches
    Movado Cronograph - Can't remove pin!
    you need to push it thru wit a ling "needle type" toolin order to get it out. it has to be strong enough so that it doesn't bend also because it's quite stuck in there pretty good. thats part of the quality you get from a movado.
    Jan 26, 2008 | Movado Kardelo 0605479 Wrist Watch
    Watches Logo
    103 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
