Question about Milwaukee Electric Tool 6230 Electric Band Saws
When the band saw is turned on the blade come off as it turns
  • 2,176 Answers
Could be several problems, The blade could be worn, tires worn, axles loose and the front pulley support could be bent. I would try and watch to see what wheel it starts coming off of and then concentrate on that to find the problem. Let me know if you need more assistance.
Posted on May 18, 2011
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Delta 28-160 band saw 3 wheel, blade keeps coming off
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Nov 27, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Blade will not stay on cutting mark, even a straight line. My blade looks like a quarter inch on a nine inch band saw.
clean dust off the wheels, center the blade get it tracking and tension it so it has a medium high to (wide blade) high pitch (narrow blade) twang like a guitar sting when plucked with the saw turned off
Feb 19, 2011 | Ryobi 9 in. Benchtop Band Saw
Why doesnt the wheels on my band saw turn when I turn the saw on?I can't even turn them when the saw is off.
Most likely the blade has come out of position and jammed. One place to check is at the guides just above and below the table.
To be sure the guides are correct, Google on "adjust band saw" to find out how to adjust them.
Jan 19, 2011 | Craftsman 12 Tilt Head Band Saw Owner...
The blade bends inward as soon as it touches a workpiece, cutting unevenly.the blade guides top and bottom are adjusted properly
The tension on the blade is too low. There is a knob up on top that when tightened will raise the upper wheel, tightening the blade. With the saw turned off, open the cover and turn the knob, you will be able to see the wheel being raised and the blade straightening out.
Apr 22, 2010 | Ryobi 9 in. Benchtop Band Saw
Turn saw on, Curcuit pops immediatly
The motor is bad. It is drawing too many amps.
Jan 28, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
HOW DO YOU CHANGE THE BLADE AND TIGHTEN IT UP THE BAND BLADE CAME OFF & I DONT KNOW HOW TO GET IT BACK ON
Unplug it. Open the cover(s). Find the tensioning knob - this is usually right on top, and it is raises the top wheel (or ins some cases an idler wheel) - thereby tightening the blade. Lower the top wheel by turning the tensioning knob a few turn counter-clockwise. This will give you enough slack to re-install the blade. Wear leather gloves and reinstall the blade. Tighten the tensioning knob a bit. Turn the wheel by hand a little to see that the blade tracks OK. Tighten it a bit more. The correct amount of tension pretty much has to be determined by trial and error. If the blade comes off, or bends too much while you try to cut, or cuts poorly, then it's too loose. If you over-tighten it you can break the blade or prematurely wear out your machine. Close the cover and plug it back in. You can adjust the tension with the cover closed, and you can even tighten it while the saw is running. But I wouldn't loosen it while the saw is running.
Jan 20, 2010 | Ryobi 9 in. Benchtop Band Saw
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Apr 05, 2009 | Dewalt dw3988 14tpi portable band saw...
Help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Jan 29, 2009 | Saws
Milwaukee Electric Tool 6230 Electric Band Saws Logo
143 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
