Question about Hardware & Accessories
We installed a new ceiling light fixture in our hallway. I used the 13W CFL bulb. Just recently, I turn on the light and a hour or so later it turns off. It takes a few minutes before I can make it turn back on. Any ideas?
    Sergeant:
    Champion:
  • 338 Answers
DON"T USE TILL YOU FIX- the connections inside fixture are getting hot and expanding- OPEN SHORT_FIRE HAZARD- that is why going out after an hour and then works after a few minutes of cooling- take down and check you connections
Posted on May 18, 2011
Can't find replacement bulbs in Toronto. They are VIVA PBCFS1370.
Tina - I just tried to find this bulb for one of my customers. Amazon had a bulb listed with a photo of the VIVA PBCFS1370 bulb. If you read the comments - someone said they sent a Levitron bulb which does not fit. I think you are stuck going back to where you bought the Hunter fan (I assume big box store) or to Hunter directly. A regular 13W GU24 bulb seems to be slightly too wide to fit in the fan. Hunter's part number is 6755101000 and they were $12 each - but that is in the USA. Isn't that a nuisance!
This links to Amazon site - appears to be wrong bulb:
Leviton 9865 13W Compact Fluorescent Replacement Lamp
or could be this one:
TCP 33213SSP 13 Watt 60 Equal 2700K Warm White CFL Spring Lamp Squat GU24...
Oct 04, 2015 | Hunter 52" Ceiling Fan With Light And...
Can I use a 23W CFL bulb in place of a 13W, if the desk lamp says to use a 60W max bulb?
OF COURSE less than 60 watts is it not . and they are a lot cooler
May 08, 2015 | Dryers
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
CFL bulbs for fan fixture
I had a simple question and you wanted me to pay you to answer it.
I am still hoping to get a CFL lightbulb with socket size E17 to provide more light for my kitchen, but you won't help.
Screw you all.
Sherwin
Oct 06, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hardware & Accessories Logo
27 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
