Question about HP PSC 1315 All-In-One InkJet Printer
Ethernet router not working
I have had a D-Link Ethernet router for about three years, no problems until recently, after a lightning storm it has failed to work. Turne things off and back on. I tried the reset, but it is pretty deep so may not have got it. $50 new. Is it junk?
  • Anonymous Aug 17, 2008
    perso cd installazione
    An expert who has answered 500 questions.
  • 564 Answers
More like lightning toast..time for a new one..and protect it with some power protection this time.
Posted on Aug 20, 2008
My D-Link 2750U router is not working from last evening due to the heavy rain, lightning and storm. What should I do?
If you have lost three devices I'm sure you had ALL your computer devices on a UPS/Surge protector? Always connect ALL computer devices to a Power strip, UPS, or even better, unplug or switch off when not in use. A power strip with Surge Protection will help, most have a power switch/ Circut Breaker, to shut down ALL devices connected when not in use.
Feb 14, 2013 | Computers & Internet
My internet works but it stopped working on my xbox during a lightning storm and ive tried all my imputs
That very common when systems are connected directly to a router/modem after lightning storm. your best bet is buy a usb wireless adapter.
Aug 30, 2011 | Microsoft Xbox 360 Console
My D-Link DI-604 was working well. However, recently, I noticed that there is a delayed in power supply. It doesn't turn on immediately. It would take several minutes before it turns on. Sometimes, no...
I've had a few D-Link power-supplies fail on me, over the years.
Just purchase a brand-new router, for $20 t I've had a few D-Link power-supplies fail on me, over the years.
Just purchase a brand-new router, for $20 to $50.
Mar 08, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
What is theam.if we apply theam the wole appreance will change or only on desktop
How Can One Cable Modem Work With Two Wireless Routers? By Terry Stockdale Leave a Comment In How to Fry a Wireless Router or Two, I wrote about my brother's experience frying a pair of wireless modems in a lightning storm. Last week, I talked about what had happened, why it happened, and what he could do to prevent the problem in the future (this was the third set of routers, plus he lost a computer motherboard in that storm).
This week, we'll look at his network layout, and why he could not get the network to set up properly.
To summarize the situation, he has an office an a shop, with computers on his network in both locations. Some connect via wired connections (Ethernet), while others use wireless connections. His Internet cable comes into the office first.
In the past, he first used Linksys wireless routers. Then DLinks. This time, he chose Belkin wireless routers.
The incoming cable (standard cable-company RG6 coaxial cable) connects to the cable modem.
Then, the cable modem connects to the WAN (wide area network "Internet") connection on the router.
The local wired ports on the router provide connections for two wired computers. Notebooks connect via wireless connections. Finally, one wired connection on the router is used to connect an Ethernet cable that runs 250 feed to the office from the shop.
That cable was the lightning problem, as it runs outside in a conduit just a little bit underground. Effectively, he's got a 250 foot antenna looking for the electromagnetic pulse from a lightning strike. Most of us don't worry about that because our equipment is so well grounded in the house, plus the Ethernet cables we use are much shorter lines. Even if we have underground cable company lines running from their switch boxes to our houses, those lines are usually only exposed about 40 to 50 feet before they enter the dwellings.
Back to the situation. When he hooked up his replacement routers, the router at the shop immediately worked. Not so, on the router in the office. The Ethernet light and the Activity light just poounded away, blinking and blinking rapidly. But, nothing connecting to the router could get to the Internet.
If they connected a computer directly to the Ethernet cable in the office, without running it into the router first, it worked just fine. But, with the router in place, it didn't work.
The problem was the way he connected the two routers. The problem is that there is no Out Of The Box connection that will work reliably. At least one thing, usually two, has/have to be tweaked one way or another.
As one might guess, the easiest way to connect would be to connect one router's WAN connector to the cable modem, using Ethernet cable, and then use Ethernet cable to connect one of the Local Area Network (LAN) connectors on that router ot the WAN router on the other computer.
There is a problem with this setup, but it's easily solved. First, if you're using identical wireless routers, as he was, the wireless routers are both trying to use the same IP Address range and subnet mask for their local area networks.
That works fine for the first router, which is connected to cable modem. On the cable modem side, it gets an IP address on the Internet Service Provider's network - often an actual Internet address and not just a private network address. On the local area network, it assigns the IP address range specified in its setup menu. This often varies by manufacturer. In the case of Linksys, this is 192.168.1.x. In the case of the Belkin routers he bought, it was 192.168.2.x.
The problem occurs at the second router. On it's WAN side, it sees a 192.168.2.x network - but it's default setting tells it to give 192.168.2.x addresses on it's local area network side, too. In other words - it's confused. It doesn't know where to find the Internet because both networks are assigned the same addresses.
The solution was to disconnect the second router's WAN/Internet cable, connect to it via a wired computer, and tell the second router to use a different IP address range. We chose 192.168.3.x.
We hooked up the Ethernet cable to the Internet/WAN side of the router again. The router started working fine, normal light blinks for activity, no more confusion. The computers could get to the Internet just fine.
Problem solved.
That solved the Internet connection problem. However, no computers in the office would be able to share files or printers with the shop, nor would computers in the shop be able to share with the office. That was both acceptable and intended, in this case.
It could be done; however, that would require a different configuration on the routers and connections.
Jan 05, 2011 | Computers & Internet
My router flashes DSL, no light on the internet, ethernet and wireless flash together, and power light on. no wired or wireless internet. solution? the afternoon it happened, a lightning storm came thru...
Hey danielbartle,
Since a lighting storm came through there is a good chance your router has been fried.
I would first direct connect via your modem to see if you get a internet connection and rule out your modem as a problem. If that doesn't work I would try another ethernet cord to rule out your cord is a problem. If you get no connection directly through your modem, I would contact your ISP with your problem.
If you get a connection I would then reset the router by unplugging and waiting 30 seconds and plugging it back in.
If still nto succesful I would reset your router to defualt settings by a small button you will find on back.
If none of these work I would head to your local computer shop and pick up a new router.
Thanks for using Fixya!
Jul 22, 2010 | 2wire (1000-400108-001) Router
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
WRTP54G Ethernet problems
it almost sounds like a failing pc board in the router just old and dying could be firmware try updating , reboot the router before the firmware update you dont want it going out during that
Feb 24, 2009 | Linksys Wireless-G WRTP54G Router
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
Ethernet Port failure on Acer Aspire T180-GB7Z
Type of your O.S (Operating System) Windows, MAC, Linux Etc?
May 12, 2008 | Acer Aspire™ T180 PC Desktop
Rg54g3 router problem
Lightning seems to have zapped the Ethernet port on the Modem side, the WAN port, this is quite common with telephone and cable line surges.
Consider your router smoked.
Apr 07, 2008 | MSI Wireless-G RG54G3 Router
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
