Question about Toys
I have a lionel 223 alco diesel made 1963.when it goes forward it switches to reverse on its own . I noticed that when this happens the light dims
  • willard138 May 18, 2011
    Thank you for solving the problem
    President:
  • 1,509 Answers
Se a volt meter and with the transformer turned on and a loco or a car that draws lighting power on the tran=ck use the volt meter turned to a low voltage and test the connectors as their shoulnot be any reading across the connector ( no reading) from one side of the connector to the other if their is disconnect the track and reconnect it wirebrushing the pins or electrical cleaner. the wheels of the loco can benifit from this treatment too and there's wires coming from the trucks to the motor and switch ( reversing relay) This wire can be frayed and partly broken and may need to be replaced. The centerr rail wheel sometimes looses it's tension in the spring that makes it ride on the track and this also can stand a good cleaning and it's wire can alson by old and near broken.. thjey get stiff over time and the wire does'nt let the thrid wheel ride on the track all the time with the right pressure interrupting the flow of current. Many on these LoCo's have a switch in the cab that lets the loco only go forward. this switch can also get dirty and can benifet from a blast and cleaning with electricl cleaner.
Posted on May 18, 2011
  • dennis youland Nov 20, 2011
    bad ''e unit switch'' use CRC brand 226 cleaner , best there is......
    easy fix.....
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Forward and reverse switch
Are you using the transformer that came with the train set? This has forward, reverse, and neutral available?
Jan 19, 2014 | Lionel Trains The Polar Express O Gauge...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Lionel Thomas remote chuff off switch does not work
The slot for these switches is too small to allow the slide to move all the way it needs to move. The fix is to carefully file away some of the plastic from the switch slot.
Jul 13, 2017 | Lionel Toys
My brand new Sante Fe "O" guage quit running in the forward direction after about 15 minutes on Christmas Eve. I took it to the dealer and was treated rudely by the repair person. I was accused...
If sounds like something is wrong with circuit board that controls direction. If it is new it should still under warranty. Find a decent repair shop from Lionel and bring it in.
Feb 01, 2011 | Lionel Santa Fe Diesel Locomotive Engine...
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
Lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Dec 17, 2008 | Lionel New Haven Freight Train Set
Toys Logo
129 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
