My asda wecam CP-68L isn't working. when i plug it into my comptuer it had a green led light on it but my computer does not register it. it says to download the software but i have misplaced it
  • 386 Answers
Assuming you're using Windows...
Hi Sophie,
Plug in that webcam. Assuming it's a USB one...
Do a right-click on My Computer and choose Manage; On the new window, left pane, click on the Device Manager node, and in the right pane right at the top where it states your computer name, do a right-click and choose "Scan for hardware changes". Hopefully it will get detected.
If not, scroll down to the USB controllers branch, and do the same right-click > Scan for changes. Hopefully, it will be detected, and then follow on-screen instructions regarding drivers install and configuration.
Apart from that, a visit to Windows Update website should sort you out: look there for available updates, driver updates in particular.
Good luck. Don't forget to rate;) Gary
Posted on May 18, 2011
The numeric keypad turns on but isn't responding
Go to System preferences, Keyboard. Try changing one item at a time to see if it recognizes the keypad. Restart the computer with the keypad plugged into USB port. I dialog box should appear to give you instructions in syncing the new keypad to the Mac.
Dec 27, 2012 | Computers & Internet
I NEED DRIVER AND IT'S KEY OF SMART PRICE CIF WEBCAM MODEL CP-68L
1st You download Webcam Driver.
DRIVER FOR MY CAM After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Ezonics Camera Drivers for Windows XP Vista Windows 7
Nov 10, 2012 | Ezonics Computers & Internet
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
Daownload cp-68l smart price web cam drivers
i can do that remotely, you will have to pay $15 with your visa card
Mar 10, 2012 | Creative Labs WebCam Live!
Won't turn on
Your computer isn't recognizing the camera and you may need to install some software in order for it to do so.
Another thing? Are you trying to charge it? In my experience, Jazz cameras will only charge with an adapter that is usually included with the camera. Hope this helps.
Jan 19, 2012 | Jazz DV-179 Digital Camera
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
Have not used my Garmin since January 2011. Sitting on shelf. Plugged in to my car charger and would not turn on. Would this mean it needs charged?
After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
Apr 18, 2011 | Garmin nuvi 1490T GPS Receiver
I just bought a smart price webcam fron asda but cd rom wont open where can i find a driver for it model number cp-68L
WITH VISTA DRIVER IS ALREADY ON YOUR SYSTEM.... GO TO DEVICE DRIVERS,RIGHT CLICK ON DEVICE,UPDATE DRIVER. CHOOSE FROM A LIST. YOU NEED TO FIND C:\WINDOWS\SYSTEM32\DRIVERS\USBVIDEO.SYS BINGO IT WORKS
Apr 18, 2009 | Ezonics EZCam Plus Webcam
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
