Question about Sierra Online, Inc. Arcanum: of Steamworks and Magick Obscura for Windows
I have steamworks steam generator iron. before and even after replacing new filter steam is not comming fiter light keep flashing. iron becoming hot.
While the iron is off, Press the steam selection button at the same time as the power button. The filter light should switch off.
Posted on Oct 31, 2013
3 Suggested Answers
SOURCE: Changing the filter on a Steamworks G-1030ST iron.
Not 100% sure, but I think you press and hold steam button for a few seconds.
Posted on Jan 28, 2010
SOURCE: hi i have a steamworks iron and the iron is puting
This happens when the iron isn't hot enough to successfully generate steam (usually in hard water areas). If the iron is hot enough this should not happen. If a lower heat setting is required ie. wool do not use the steam. Hope this helps.
Posted on May 20, 2010
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
How do you test a pump on a tefal steam generater
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Irons
Hi i have a steamworks iron and the iron is puting out brown water on the steam,the filter cartridge was brown so a new one is in,will this cure the problem and is there a way of cleaning the system as i...
Apr 15, 2010 | Sierra Online, Inc. Arcanum: of Steamworks...
Dec 13, 2009 | Sierra Online, Inc. Arcanum: of Steamworks...
Have just bought kenwood steam generator iron but there are no instructions with it. the filter light is flashing what do i do
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Aug 31, 2009 | Irons
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
Steam generator iron beebs when button pressed but no steam green flashing light on aswel
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 21, 2008 | Euro-Pro Steam Generator EP8001 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Sierra Online, Inc. Arcanum: of Steamworks and Magick Obscura for Windows Logo
348 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
steve morris
steve morris
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
