Question about Apple iPod MA446LL/A MP3 Player
Ipod 30 gb non responsive
Ipod 30 gb will not turn off screen shows a check mark and indicates ok to disconnect. I verfied on/off switch was on and tried to toggle it on and off but no response. Is there any charge for you advice/assistance?
  • Apple Master
  • 2,794 Answers
Press and hold the center button while holding down on the menu button. That should beboot your IPod. Try turning off after that is done. Sometimes they hang up after docking.
Posted on Aug 14, 2008
SOURCE:
Ipod touch 3g has a white screen - any way to bring it back up?
Hi mickhon...
White Screen of Death
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Sep 17, 2011 | Apple Ipod Touch 8 GB 32 GB 64 GB 3rd...
My ipod 30 gb is also frozen on the language screen.My lock button works. Also I can reset the IPOD using the Select menu combination. Any ideas?
Have you already attempted to restore it within iTunes?
If not I would greatly suggest taking that approach to you next trouble shooting step.
When you connect the iPod to your computer, if for some reason it does not show up within iTunes; simply reset the iPod and disconnect it.
Next you will need to force the iPod into disc mode.
To do this you will reset the iPod once more, except when the apple icon appears QUICKLY release both buttons and switch to pressing the play and center button until a check mark appears.
Once you see that reconnect the iPod to your computer.
Note: it may take a few minutes for iTunes to pick up the device. I recommend waiting at least five minutes before deciding it will not load.
After that restore the unit as you normally would by clicking Restore within the summary tab that loads when you first connect the iPod. Follow all and any on screan instructions.
Please do let me know if this does not resolve your issue.
If it does not, I would suspect that your click wheel needs to be replaced. You can find manuals and instructions at the following web address.
http://www.ifixit.com/Guide/Browse/iPod
Dec 29, 2009 | Apple iPod nano
Ipod non 1gb will not come on
The unit is being manually managed. You need to un-check "Manually Manage". See http://support.apple.com/kb/HT1351
-=/ MLF /=-
Oct 21, 2009 | Apple iPod nano
Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
If all the above checks out OK, replace the touch pad.
May 30, 2009 | Kenmore 2205x Top Load Washer
Locked ipod nano
Did you first slide the hold switch to HOLD and then back before holding the menu and center buttons down together? That worked for my iPod nano 4th generation after it "locked up" and became non-responsive.
Mar 08, 2009 | Apple iPod nano
Ipod 80gb classic won't restore
try going below for further assistance from apple
http://support.apple.com/kb/TS1463
I hope this helps
Dec 08, 2008 | Apple iPod classic 6th Generation Digital...
Ipod is on do not disconnect. cannot turn off
Just do a reset. Hold down menu and select till the screen goes blank. The iPod logo should then show up and iPod will start up again as though just turned on.
Otherwise, take the back off, disconnect the battery and reconnect again.
Nov 19, 2008 | Apple iPod MA446LL/A MP3 Player
Frozen iPod
move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Oct 23, 2008 | Apple iPod nano
My ipod 30 GB is showing only white screen
Most probably restoring should help ..... Restore with itunes....
Oct 12, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
330 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
