I cannot insert paper all the way into the tray.
    Scholar:
  • 120 Answers
This is the problem of your printer paper feeder. Now i am quite unknown about your printer model.If it is epsoon r serige Please deasemble the printer then open paper fedder. then the plastic roll that are inside the fedder. There is a spring is inside the roll. put off the spring and re asemble the printer. I think it began work again.
Thank you.
Posted on May 18, 2011
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Paper jam error with my canon mp180 printer and it wont let me do anything i have checked the printer numerous times to see if theres anything in there and theres not.
This problem can occur, may be there is no paper jam inside but improperly inserted paper in the paper tray.
Check and verify that there is no paper or a piece of paper stuck in the roller or the belt. Remove all the paper from the paper tray and insert them again, do not fill the paper tray fully,
Aug 24, 2011 | Canon PIXMA MP180 All-In-One InkJet...
The cd tray on my computer will not open
HI
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
I have a printer canon inkjet mp140 and i don't know how to insert the paper from the tray that is down or from the upside tray
Well, you should insert the paper "from the upside tray". Follow these steps:
Align the edges of the paper before loading it;
Open the paper support of "the upside tray" and pull out the paper support extension;
Open the paper output tray ("tray that is down");
Adjust the position of the paper thickness lever;
Load the paper in the auto sheet feeder with the print side facing UP;
Align the paper stack against the right side of the auto sheet feeder.
Pinch the paper guide and slide it against the left side of the paper stack.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to load paper
Your model has two trays on the front. The bottom one of these two is where you load the blank paper.
1. Raise the output tray to load paper into the main input tray.
2. Slide the paper-width guide to its outermost position.
3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
• Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
• Make sure all the paper in the stack is the same size and type.
4. Insert the stack of paper into the main input tray with the short edge forward and the side to be printed down. Slide the stack of paper forward until it stops.
5. Slide the paper-width guide inward until it stops at the edge of the paper.
Do not overload the main input tray; make sure the stack of paper fits within the main input tray and is no higher than the top of the paper-width guide.
6. Lower the output tray.
7. Pull the output tray extender towards you, as far as it will go.
I hope this helps!
Dec 08, 2009 | HP Photosmart C5280 Printer
How to open tray when it don't want to open
You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Aug 11, 2009 | Microsoft Xbox 360 Console
PAPER TRAY NOT RELEASING
After puting paper in the tray you should press the start button. GOOD LUCK.
Nov 20, 2008 | Samsung SF-560 Plain Paper Laser Fax
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
jasbo
jasbo
