Question about ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775)
I broke off the pin for the positive in the computers power hole. Need a step by step to take it apart G
    President:
  • 1,812 Answers
Click the bellow link ,and do steep by step.
http://www.cesgeekbook.com/2009/12/asus-eee-pc-1005hab-tear-down.html
Hope this helps. Let me know if you need more informationThanks
Posted on May 18, 2011
1994 toyota camry key broke off in ignition and now need to replace it.
You must somehow get the ignition to the "on" position. Remove the cover around the steering column and there should be a hole below the ignition switch/key cylinder. Insert a drill bit (a size that can go into the hole), tap it with a hammer until the key cylinder can slide out. Remember in order to do this, the key must be set to "on". If you are unable to to get it to the "on" position. You must drill the lock pin inside that hole until the key cylinder can be removed.
Jul 26, 2011 | Toyota Camry Cars & Trucks
Tip
How to reset your bios password. Step 1: Power off you computer and unplug power...
Step 1: Power off you computer and unplug power cable.
Step 2: Open the computer case so that you can see the motherboard.
Step 3: Find the 3 pin jumper on your motherboard and put it on the other pin. Ex: If it is on 2 and 3 you will want to put it on 1 and 2.
Step 4: Plug your power cable back into you computer and turn it on. (Note: Your computer will not load you operating system.)
Step 5: Shutdown your computer and unplug it again.
Step 6: Put the jumper back into it original position.
Step 7: Plug your power cable back in and turn your computer on.
Now you bios password should be reset.
To enter the bios press the the F2 or Del key when your computer is turning on. (Note: This varies for different manufacturers.)
I hope that this helps you!
HelpDeskMan
on May 28, 2011 | Computers & Internet
How do I change the ignition switch in a 1995 F-350? The original key was lost.
*If* you had the key these are the steps: Insert the key and turn to the RUN position. There is a small hole in the steering column below the ignition switch. Insert a 1/8" drill bit (or something similar size) and push upward on the retaining pin in the hole. As you do this, pull out the cylinder lock. It should come right out. To reinstall, turn the new cylinder to the RUN position. Again depress the retaining pin and insert the switch into the steering column. Make sure the new switch is completely seated & aligned before you turn to the OFF position. This will let the retaining pin extend into the hole.
Because you do not have the key you will need to pick (or have the lock picked) before you can replace the lock cylinder.
Sep 12, 2010 | 1995 Ford F350
Cam sprocket timing for 86 Toyota 2SE engine
cam sprocket gear for nissan v6, I need left and right both, so this parts is for obtain more power of torque, were I found this parts?
I looking for that could move some degres when I decide.
thanks for u time, raymond m.
market_bros@prodigy.net.mx
Feb 21, 2010 | 1987 Toyota Camry
How do you replace the headlight assembly on a 99 Pontiac Grand Am?
  1. Open the hood to your Pontiac Grand Am. Have the car keys on you, but not in the ignition and make sure the lights are in the "off" position.
  2. Step 2 Locate the splash guard and the plastic push pins that hold it down. It runs along the entire front frame rail. Removing the entire splash guard will make it easier to to remove even one headlight on one particular side.
  3. Step 3 Remove the pins by lifting up on the center of the pin. Pull it up about 1/4-inch and then pry the pin insert and pin out of the hole.
  4. Step 4 Locate and remove the two-headlight assembly bolts on the the top of the headlight assembly. Use the ratchet and a socket to remove the bolts.
  5. Step 5 Pull the headlight assembly forward by hand. Be careful not to scratch the lens of the assembly or scratch the paint on the front bumper.
  6. Step 6 Unplug the wire from the back of the headlight that is blown out.
  7. Step 7 Turn the headlight bezel counterclockwise (about 1/4 turn) until it releases the headlight from the back of the headlight assembly. Extract the old headlight and discard it.
  8. Step 8 Insert the new headlight into the headlight assembly. Be careful not to touch the glass of the bulb. Handle it only from the bottom.
  9. Step 9 Replace the bezel and turn 1/4 turn clockwise until it locks into place.
  10. Step 10 Plug the wire back into the headlight and rest the assembly onto the bumper gently so you can turn on the lights to test and make sure the headlight it working properly.
  11. Step 11 Insert the headlight assembly back into place. Replace and tighten the headlight assembly bolts.
  12. Step 12 Put the splash guard into place and place the push pins into position. Insert the pin and its insert into the hole with the pin still in the "up" position. When the insert is seated flush to the splash guard in the hole, simply push the pin down to lock.
Jan 30, 2010 | Pontiac Grand Am Cars & Trucks
Self threader won't work
the needle should be in the up position or the threader won't come down, still when it does, you have to get the thread right across the hole in the needle for it to catch,
another problem is that you bent or broke the center pin that pulls the thread through the needle,
the tip that comes to the needle has three parts, the two outer ones that wrap around the needle and the center pin that goes through the hole in the needle,
If this is bent you may be able to bend it back if broke you need to get it replaced
take a good magnifier and take a look at the center pin!
Hope this helps
moni
Sep 06, 2009 | Singer 3116 Simple
The ignition switch is damaged and I need to replace it. Someone attempted to drill it out and the drill broke off in the lock, so the key can no longer be inserted.
Do not drill out there is a pin hole in the side of the switch visible after removing the covers around the swithch you may need to remove the steering wheel I never had to turn the ignition swith to on position and then put a pin or small drill bit in the pin hole push in on it and then simultaneously pull out on the chrome key tumbler wiggle it abit while pushing in on the bit to remove center tumbler assembly/contacts.
Aug 03, 2009 | 1993 Ford Bronco
Acer Aspire 4520, power jack
You may be able to buy the whole assembly on Ebay. I bought one for my averatec laptop and it just popped into place, no soldering. It was about $20
Sep 06, 2008 | Acer Aspire 5610-4648 Notebook
My hp zv5034us power plug center pin broke off need to know if positive is on top side of board or bottom so i can rig something up, or where to find schematic thank you
Its a common problem on that model , U need to pick apart every part to the board and then solder the pin.
Manual:
http://www.retrevo.com/support/HP-ZV5000-Laptops-manual/id/610dj280/t/2/
Jul 16, 2008 | HP Computers & Internet
ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775) Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
