Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
My Badger 5 disposal leaks from a 3/8 inch vertical casing split just above the discharge line. Is this repairable?
Disposal leaks are not repairable.
Once the metal rusts out, you replace it.
I wrote ez disposal installation tips from years when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 18, 2011
I have a badger 9 garbage disposal unit, and it leaks after installing from the discharge outlet at the top of the discharge tube under the side flange. I replaced a badger 1 and I used the old gasket as...
Location of leak is not known for sure.
Sounds like leak is where tubular drain pipe connects to side of disposal?
If leak is where disposal connects to sink, typically this connection is sealed using plumbers putty.
Open following link for disposal instructions:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
1) If leak is at rubber gasket for tailpiece connection on side of disposal:
I don't know if your local home depot sells gaskets. Probably not sold separately.
2) Go to home depot and take rubber gasket out of a new garbage disposal box.
3) Or buy new disposal with a gasket, use the gasket and return disposal saying that part was missing..
4) To seal old gasket, use rectoseal white pipe joint compound.
Cover the gasket with rectoseal and then assemble parts.
Open following link above for photo of rectoseal.
I always use rectoseal on tubular drain connections for 100% seal first time every time.
5) Take a moment and rate answer:
Sep 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 disposal is leaking from the side whats wrong
Check where leak is coming from.
1) Run water until leak starts. Use dry paper towel near top of disposal to see if sink strainer is leaking.
2) Move paper towel down and check where dishwasher connects to disposal.
3) Move paper towel down to tubular drain tailpiece.
4) Water should run down side of disposal if sink strainer, dishwasher connection or tailpiece are leaking. You can fix these problems using tips below.
5) If disposal is rusted out, then water will leak out of bottom or side of disposal body.
There are no repairs or repair parts for disposals.
I wrote EZ installation tips for garbage disposal from when I worked apartment maintenance that will save time and sometimes money:
Feb 19, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
If a Badger 5 garbage disposal is leaking from the bottom center, can it be repaired? Joyce
If the disposal is leaking, then it is rusted out and needs replacement.
Check if the leak is dripping down from above.
There are no repair parts for disposals.
I wrote EZ steps for replacing disposal from days when I worked apartment maintenance.
Steps might save time and money.
Feb 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking at exit connection
Well you must have leak. You need to remove the clamp that is holding the hose to the disposal then remove the hose. check the end of the hose for splits or distortion you should have enough free play in the hose if need be to cut an inch or so off it if you see a problem just cut it stright across. Then look at the clamp if that dosn't look right bent or other wise damaged replace it. Some disposals however have a threaded connection in witch case take the connector apart and check for seals that are distorted or compressition fittings orings that are ripped. But these are all hardware store items that cost pennies. then reinstall and check for leaks
Dec 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking by discharge tube
All you need to do is tighten the two screws on the discharge pipe (right on the side of disposal.) There is a gasket that needs tightening under the pipe fitting.
Sep 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Dec 20, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
59 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
