Question about D-Link DWL-G700AP 802.11g/b Wireless Access Point
Can I use the dwl-g700ap as a repeater? - D-Link DWL-G700AP 802.11g/b Wireless Access Point
  • 365 Answers
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
Posted on May 18, 2011
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
AP does not work in Repeating Mode?
check your wi fi is enabled on ap settigns also che k broad cast ssid is enabled on it.
Apr 27, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
I can't hard reset my DWL-G700AP even though i press the button longer than 5 seconds. the device doesn't reboot. what seems to be the cause?
do one thing pull out the power cable from the device after then same time put the power and press the reset button on same time press up to 10 sec after then press one or two time then you get it
Apr 14, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
I receive excellent signal from DLink dwl-g700AP but can't browse
On this tip you can find an easy check list let me know if you need more help
Feb 02, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
But the DWL-G700AP...
Is this access piont connected to a router? Can you get online through the router? If you can go online through the router also check the status of your wireless connection. Make sure its connected and it's getting a valid ip address.
Aug 22, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Factory reset dwl g700ap
Bill,
I have here the steps on how to reset your device.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Jun 05, 2008 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
D-Link DWL-G700AP 802.11g/b Wireless Access Point Logo
694 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
