Question about Cook's Essentials Smoothie Maker Work Top Blender
We have a Cook's 5 in 1 Power Blender. When making a smoothie today, the jar got stuck to the base. When plugged in the units blends, but it will not turn to shut off. The jar does not move past the lip of the base unit in order to get the container removed. Please let me know what I need to do in order to release it. Thanks.
5 Suggested Answers
  • 5 Answers
SOURCE: COOK'S ESSENTIALS BLENDER CESS700B GASKET
Go to: http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3694&secid=53&linkon=category&linkid=91 My Cook's Essentials is just like the Back to Basics model SE 2000. Yours may be one of the other models, click on replacement parts at he top. I hope this works out for you too.
Posted on Feb 12, 2009
  • 5 Answers
SOURCE: Cook's Essentials Smoothie Mixer
Cook's Essentials appears to be made by Focus Electrics, my model is an SE2000 in Back to Basics Brand.
f
klipsan
  • 64 Answers
SOURCE: need a replacement gasket for
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
Posted on Mar 03, 2011
  • 910 Answers
SOURCE: my cook's essential smoothie maker
This uses the same parts as a Back to Basics Smoothie Elite SE2000 but unfortunately no one now stocks the pitchers.
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=3694&secid=87&linkon=subcategory&linkid=90
Posted on Jun 15, 2011
Best blender brand for smoothies and juicing?
I would recommend to invest in a high quality blender that can perform all blending operations. If you're going to blending a bunch and need high speed blender to prepare smoothies and juices quickly. Vitamix will be a great option.
GroomNStyle Best Kitchen Blender Reviews 2015
Jul 29, 2015 | Blenders
My blender is model# KSB5 & it works fine; the problem is the 'jar' is stuck onto the unit. I cannot remove the canister no matter how hard I try. Help?
This is a most unusual case, under the circumstances I would contact KitchenAid for a solution, have you tried turning canister clockwise and anticlockwise, should unlock in "anticlockwise position" if no luck contact the manufacture.
Mar 31, 2012 | KitchenAid KSB5 Professional Stainless...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
Replacement parts
You need the blending jar seal. Order that and other parts for the blender here assuming they still support your model based on the manufacturing date code. (The manufacturing date code is generally found on a white sticker and will begin with a CA, DR, XM, or W followed by 4 numbers, or a # (number), letter, # (number), # (number) combination):
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
Depending on the material, some blender seals can be maintained with a little bit of vegetable oil.
I hope this helps.
Apr 12, 2010 | Back to Basics 600 Smoothie Plus Work Top...
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at javstarz@hotmail.com
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
Sep 06, 2009 | Blenders
My blender slowed down when I tried to make a smoothie. It doesn't seem to have the full power anymore.
If the motor of the blender is running at a slower speed now no matter what you're blending, the unit needs to repaired or replaced. Most small appliance manufacturers    { margin: 0.79in } P { margin-bottom: 0.08in } A:link { so-language: zxx } --> don't repair their units anymore, they simply replace them. If you're no longer in warranty, unless you paid over $200 for the blender, it's time to get a new one.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Back to Basics Blender Solution 5500...
Cook's Essentials Smoothie Maker Work Top Blender Logo
277 people viewed this question
Top Cook's Essentials Blenders Experts
Ross Keen
Tom Chichester
ray gallant
Are you a Cook's Essentials Blender Expert? Answer questions, earn points and help others
