Rhp g61 laptop screen wont boot up, i can hear the fan, and the power and caps lock are lit what the matter
    President:
  • 1,812 Answers
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps.
If you need more information, reply me soon.
Thanks
Posted on May 18, 2011
I have a HP G61-327CL Notebook that will not start-up. I have gone through all of the HP solutions to no avail. At their suggestion I have even replaced the Motherboard. With the battery out and the A
Try this turn on the laptop. even though you don't see the screen lit up it is on. do a simple test .eject the cd tray. now that you know it is on plug the laptop power cord in. turn the laptop vertical with the laptop screen slightly open let it stand up vertical for about 1 hour or more..after time has elapsed unplug the computer and power it off. quickly place the laptop in a upright position close the screen let it sit for one minute power on the device. walla it powers on this not a fix it is conformation that the laptop in question has a AMD chip which confirms the motherboard malfuntioned .buy a new laptop and steer clear of kn-owned defective products .
Dec 04, 2014 | HEWLETT-PACKARD HP G61-429WM Notebook
Laptop screen wont boot
If you don't see the initial BIOS screen you could have a problem with one of the following.
  • A bad motherboard
  • Bad memory
  • In some cases a bad Hard drive
Remove the hard drive and memory (both typically removed from panels on the back. Try rebooting. If you get the HP BIOS screen then either the memory or hard drive is bad. Add each back in one at a time and reboot until you find the problem device and replace. I would also power on the computer and use a flash light on the screen. If you see a faint image of what you should normally see then you have a bad inverter. Lastly your motherboard is bad, not a lot you can do to test that.
Dec 02, 2012 | HEWLETT-PACKARD Hewlett Packard HP Mini...
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Toshiba Sattlite, boots but black screen. Caps Lock light is on and F10& F11 key is okay.
Corrupted operating system. Start over with a restore disc and if you do not have one buy one you will need it from the factory. Re-install the whole system over again. Insert the disc in the slot and power it on select boot from DVD or CD-Rom which ever you have. Follow the onscreen instructions. John
Apr 09, 2012 | Toshiba Satellite L305-S5907 Laptop
I have a HP dv7 laptop and the screen stays black when I try to turn it on. When you press the power button you can hear the fans kick on for a mintue then they stop and while the keyboard lights stay...
Hi
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 13, 2011 | Computers & Internet
HP G61 NOTEBOOK PC BIOS BLINK ERROR CODE 2 BLACK SCREEN LED LIGHTS ABOVE NUM LOCK KEY AND LED LIGHTS TO LEFT OF CAPS LOCK KEY FLASH 2 BLINKS.NO MONITOR WHEN HOOKED UP TO AN EXTERNAL MONITOR.CD DISC DRIVE...
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
Mar 24, 2011 | Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
