Question about Kenmore Dryers
Kenmore 600 Series Dryer heating element comes on, but will not shut off. What should we do?
    Sergeant:
    Champion:
  • 252 Answers
With your dryer not running, touch the to surface. If it is to hot to tough then, iIt is your elements. I know this sounds weird, but one of your elements is touching the grounding housing and making a connection. This is not safe to use. I recommend to unplug it or through the breaker to it, until you get it fix.
Posted on May 18, 2011
4 Suggested Answers
  • 57 Answers
SOURCE: Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: i have a 600 series kenmore dryer and the heating
Sorry to read about your problem, I hope this helps you out.
sounds like your start button is stuck on...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 20, 2010
heatman101
  • 43501 Answers
SOURCE: I have a kenmore 600
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 10, 2011
600 series gas drier runs but no heat
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 25, 2011 | Kenmore 600 6962 Dryer
I have a 600 series kenmore dryer and the heating element turns on when i set the timer and before i push the start button
Dec 20, 2010 | Kenmore 600 6965 Electric Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Why doesn't the 600 series kenmore dryer have heat?
remove the back and check the heater box fuse and heating element,the heater box is on the right,the fuse is on the left side top,the element is the bottom half of heater box-mike
Feb 17, 2010 | Kenmore Dryers
Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Aug 10, 2009 | Kenmore 600 7965 Dryer
Jun 20, 2009 | Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
152 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
