Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
We have a fridgiaire dishwasher and the heat is there but when we put a tablet in it and turn it on it doesnt spray water eonough to melt the tablet and we always find it on our dishes when the cyale is over, we have tried to clean the filter and pull the hoses and clean them also, were stuck now can yall please tell me what to do?
  • Frigidaire Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 18, 2011
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Tip
What to do if your Dishwasher isn't cleaning well...
Check the following when experiencing poor cleaning results:
- Dispenser (Where you put the Dishwasher Tablet or Powder)
Make sure that the flap holding the powder in is not loose.
Make sure it is dry before ever putting in powder.
- Dispenser (Flap Type)
To check if it is still opening for the Spray Arms (Spray Arms need to throw water on the Powdered contents to wash the dishes) - Put the Dishwasher in a cycle, and halfway through the cycle, open the door. if it has not opened then maybe the solenoid/actuator needs to be replaced.
- Program Selector (Not the component, the function selected)
More time consuming programs are more likely to wash more effectively, try selecting these with a higher heat setting instead of your usual programs like quick wash etc..
- Machine overloaded.
Make sure the baskets are not overloaded with dishes, mugs & glasses as this can make spray arms find it more difficult to clean between them
- Soap
In tests regarding powder vs. 3 in 1 tablets like "finish", it has been shown that powder gets dissolved much better, this is because the 3 in 1 tablets are designed to disintegrate on certain heating phases of only a select few brands of Dishwashers. So if you are unsure, or experiencing undissolved tablet - Use powdered dishwasher soap instead.
- Salt container
Refill the Salt container every 3 - 4 months depending on how frequent you use the dishwasher
- Spray arms
These can often be clogged with dirty water etc. clean these with toothpicks and pressured water.
- Filter
Clean these every time after a wash, usually found at the bottom of the dishwasher where water drains away.
- Over the counter products
These can be bought at Appliance spare outlets or even at some supermarkets. Use these as the directions indicate.
- Element (Last step if not improved)
Replacing a element is usually a last option, if no improvement was experienced by doing all of the above it could be that the element is not heating at the right temperature, or not heating at all.
Either replace this yourself (with various degrees of difficulty depending to the Make and model) or get a qualified service technician to do it with you.
Hope this helps :-)
If you found this helpful, please vote accordingly.
on May 10, 2011 | Dishwashers
Why is water not heating in cycle?
Hello Kevin, thank you for your post!
From my understanding your Electrolux dishwasher is not fully dissolving the detergent tablet. It may not be an issue with the water heating up it could be a possible problem with the water not receiving adequate pressure or not enough water. Does your dispenser have any build up inside of it? Have your spray arms been recently cleaned? I would recommend cleaning the dispenser and spray arms out. I can also provide you with information regarding any heater inside of your dishwasher. In order to do so I need your model number. You can locate your model number on the inside wall of your dishwasher. With this information I would be happy to assist you further. -Matt
Feb 02, 2016 | Electrolux Dishwashers
SPRAY ARM MELTED ON FRIGIDAIRE DISHWASHER
what can cause the spray arm to get burned? is it too hot water in the water heater or the heating element ?
Aug 29, 2012 | Frigidaire FDB1502RG Built-in Dishwasher
Tablet not melting in the dishwasher and the dishes are coming out dirty
I much prefer liquid dishwasher detergent for this reason. Have you tried this? Also, I find I have the best luck when I start with hot water rather than waiting for the machine to heat the water. I do this by getting hot water to the sink (while rinsing the dishes before putting them inside) and then starting the dishwasher.
Liquid is also easier to distribute when considering the pre wash vs the main wash cycle.
Another thing you might try is breaking the tablet up before putting it in the machine.
The third thing I might suggest is you try powedered detergent for dish washers.
I hope this helps you ... thanks for visiting today.
Jan 25, 2011 | Kenmore 24 in. 16532 - Multiple Color...
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Fischer and paykell dish washer tablet doesnt melt
if that is a drawer dishwasher ck manual i believe it it says powder only the fp drawer dishwasher doesn't use much water so desn't have a lot of spray force to dissolve tablets
Dec 13, 2008 | Washing Machines
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
98 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
