Question about HP Office Equipment & Supplies
I have HP 9050mfp printer. i have a problem "31.1.13 scanner failure. tun off and on it says and i did it. but no change and i can not use my printer. please help me to fix it. Regards, amare.
    Genius:
  • 1,089 Answers
I'm thinking that in your zeal to communicate this error message to us, you copied it down wrong. Maybe you meant to type 30.1.13.
If that's the case then your printer is suffering from a communication problem between the scanner control board(SCB) and the front side optical board (Scanner).
This is a very difficult problem to troubleshoot because there is a 20 step document that must be followed.
A trained printer tech is needed to look at the printer.
Not what you wanted to hear, but if you want it fixed make the call.
Posted on May 19, 2011
  • Amare Atale May 19, 2011
    Thanks so much for your correction and update. Yes, it is 30.1.13 and I will call the technicians.
    Regards,
    amare.
HP 4500...when trying to scan, or make a copy, screen displays "Scanner Failure" and will not work. Please help.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Sep 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
HP PSC2175 show scanner failure message ans sound "crac, crac, crac,crac" please help!!!
I'm having the same problem with my HP PSC2175!!!!! Really driving me nuts now!!!!
Apr 28, 2011 | HP PSC 2175 All-In-One InkJet Printer
I just got my printer its an hp officejet 4500 model G510g. i got it not too long ago about two weeks and when i turn on the printer after it says warming up, it says "scaner failure. unable to scan,...
Your printer should still be under warranty.
Either take it back to the place where you purchased it or call HP. Their number should be in your manual.
Jan 04, 2011 | Office Equipment & Supplies
I have a hp psc 2100 and it will not print. I have rebooted, uninstalled, restalled and when completed, the printer either reads "scanner failure, turn off, turn back on" or "printer test...
Hello,your scaner seems dirty,first open the control pannel by pull out the cover then you will find some slots after removing the cover you will find a mark push them & push the pannel to down ward remove the cable from connectors.
open all the screws remove the cover over the glass & over from scanner assembly,take out the scanner assembly from printer .
After removing the scaner *** open them & clean inside ,reflecting mirrors & lence by a soft cotton refix them as open,
Note one thing the home position sencor situated as white strip insidephase of flatebed scaner clean also then .
Refix the unit as open carefully your problem will be resolved 100% ,altough it persists then replace the flatbed scaner.
Pls comment whether it works or not ....................regards... jitendra
Dec 18, 2010 | HP PSC 2110 All-In-One InkJet Printer
My hp 9050 gives me a 58.03 error which also says switch off printer and switch back on
This is a cpu error. steps to resolve error
1. replace toner cartridge
2. replace toner sensor contact assembly
3. replace the DC controller
Nov 11, 2010 | HP LaserJet 9050mfp Printer
SCANNER FAILURE
first you try with changing the usb cable and see. bye
Sep 28, 2007 | HP Officejet 4215v All-in-One Printer
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
