Question about Maytag Dishwashers
2h blinks for about 30 seconds the shuts off...or sometimes the cycle will start but only run for a short time ..10 min. or so
    Problem Solver:
  • 7 Answers
Could be one of the two microswitches in the latch mechanism. Turn off power remove inner door (torx screws) use an ohm meter to check the continuity of the two switches. Also another simple way is to listen as you open the latch slowly, you should hear two clicks if just one then that is the problem.
Posted on May 18, 2011
How do i reset immobiliser after changing ignition
it depends on the make of car but most will do a 30 min relearn.turn the key to the start position release it back into "run"wait 10 min, cycle the key from run to off and immediately turn it back to run (do not attempt to start at this point) do this for a total of 3 times and at the completion of the 3rd cycle without shutting off the key attempt to start the car
Feb 11, 2015 | Cars & Trucks
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
My set just shut off and is now blinking 10 times.
What can possibly cause 10 blinks
A.Missing/Shorted F_15V
B.Shorted Vsus
C.Missing/Shorted SUB5V, SUB9V, BT30V.
D.IC1100, IC9003, IC9004
E.Unplugged SC20, SC2
F.Possibly SU and SD boards
Information from Panasonic.
May 18, 2010 | Panasonic TC P42S1 42 in. Plasma HDTV
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Meile G638 I Plus dishwasher
Problem solved, the dishwasher starts its wash cycle with a drain sequence, the pan did not drain in time for the wash cycle to continue , thererfor locking it out on inlet/drain alarm. I removed the drain hose from the S trap, then the non-return valve from the filter basket, made sure the drain pump impelar was free, blew down the drain hose back into dishwasher to clear any waste in the pipe,then found a block in the S trap orifis, after clearing that, reasembled and test run on cold pre wash cycle this runs for aprox 10 min.customer was very happy.
Mar 30, 2008 | Dishwashers
46 sam dlp problem
This is pure conjecture but I think the cooling fan has failed or is running slow.
Check to see if it can still be heard.
This system seems to be a bit weak on reliability.
Mar 30, 2008 | Televison & Video
Dishwashers Logo
162 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
