Question about Cyberhome CH-DVD 300 DVD Player
Set up video output
I had configurated my device like ntsc video output.I changed it to pal output to see a video with this format and the tv imagen began to get up and down quickly and I haven´t could restore to inicial configuration because the imagen in tv do not stop.I have done the instructions in the operation manual and I do not get reset the dvd player. Please, help me to resolve thios problem.
My DVd is the CH-DVD 300,Progressive Scan DVD Player
  • elvirahancoc Dec 01, 2008
    I have the same problem however the TV screen is moving up and down so fast it is impossible to try and change it back to NTSC. I have tried to revert the setup back to factory settings but the advice proffered on these forums (the 20 sec 'stop' suggestion) is not working. What else can I do to restore the settings?
  • Anonymous Dec 06, 2008
    I have the same problem however the TV screen is moving up and down so fast it is impossible to try and change it back to NTSC. I have tried to revert the setup back to factory settings but the advice proffered on these forums (the 20 sec 'stop' suggestion) is not working. What else can I do to restore the settings? what can i do
  • Cyberhome Master
  • 2,794 Answers
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Posted on Aug 14, 2008
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
How do i change the output signal on my phillips lcd tv i.e pal, ntsc? I have set up my wii on the inlaws tv and it is nly displaying black and white and one solution suggested was to change the output on...
New flat panel (HDTV) units do handle PAL and NTSC, but the change is automatic when you plug the source into the TV.
For example I have an NTSC and a PAL Sony HiDef camcorder, and if i plug each one into the same HDMI port, my TV still displays vid from each unit, without me changing anything as the TV detects the format and displays as needed.
This other person may have meant resolution when you said output. Especially for the Component sockets, if you can, set the TV to its lowest resolution, maybe 480i, and reset (press reset for a few seconds) the Wii so it defaults to its lowest output resolution
See if this helps.
Jan 01, 2010 | Televison & Video
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
My rca 2002 rtdvd1 player only plays ntsc format. I can unlock any codes so it will play PAL?
Unless it's built into the settings but most players designed for NTSC will only play NTSC. Those made for PAL will play PAL.
Theres too many radical changes in video signals to make one device handle both formats.
Jul 05, 2008 | Televison & Video
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
79 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
