Question about Health & Beauty
Service manual HP8204B - Health & Beauty
I accidently got my battery charger Model #HP8204B 24VDC/4A wet I have replaced the internal fuse several times only to have it blow again and again?
The water caused a short and burnt out wires. Those wires are creating a dead short to earth. You need a new charger and the knowledge not to let it get wet again.
Sep 29, 2016 | Health & Beauty
What fuse do I need for my Merits Hp8240B
Hi 10 amp should b O/K....cheers
Aug 31, 2016 | Health & Beauty
I have a hp8204b charger. power light comes on, fan runs 1-2 seconds then quits. does this charger need replacement?
This charger is suspect I would take it to your local battery outlet and have them check it. I would not trust this charger!
Strege Mobility
Jul 25, 2014 | Select Jazzy Used Electric Wheelchair
Charger not working fan not stay on and yellow light
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
Nov 09, 2013 | Pride Health & Beauty
Need a circuit diagram for charger
Hi , sadly no company will give you that as it's propriety information. I do repair chargers, located in the UK...
Regards
Rob
www.gewizrepairs.co.uk
Nov 07, 2013 | Health & Beauty
What fuse do i need for a 24v battery charger / pride hp8204b
Try T4ah That is what CTM uses for its 24V 5A CHARGERS. Good luck.
Jun 25, 2012 | Health & Beauty
I have a HP8204B Pride battery charger 24vdc 5a 230vac, the wire to the end connector (3 pin with 2 of the pins bridged) has come away and i don't know which wire (one black, one red) to solder to which...
The red wire is positive and is soldered to pin 1. You can see the 1 on the pin (non solder side) of the plug housing or on the solder side as a raised stamp 1.
The black wire is soldered to the negative pin 2. Two of the pins are bridged to inhibit the power chair operation when the charger is plugged in. Hope this helps.
Mar 16, 2011 | Health & Beauty
THE ON BOARD BATTERY CHARGER ON MY HS1000 CTM POWER CHAIR IS NOT WORKING. WHERE CAN I FIND THE CHARGER I NEED HP8204B
Hello, This is CTM Tech Dep. Call me direct at 866-466-8168 or 909-590-1388 ex: 115 or email me at lnavarro@ctmhomecare.com. I will provide you with local dealers and low prices on 1. On board chargers or 2. Off board charger that are an option for your unit.
Thanks.
Dec 13, 2010 | Ctm HS-2800 Power Wheelchair
Health & Beauty Logo
940 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
