Question about IBM (73P8023) 146.8 GB Fibre Channel Hard Drive
I have a refurbed 146gb 15k IBM fiber drive that will not even be recognized by my storage manager. is there something that needs to be done to the drive somehow to allow for it to be seen? thx
  • IBM Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error also if its an external hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 18, 2011
Driver 530
Look in Control Panel, Administrative Tools, Computer Management, Disk Management. Can you see the drive? If Yes then change the Drive Letter. If No then look in Device Manager. Can you see the drive? If yes then see above. If No then check connection and power supply. Fixed? If Yes then smile. If No then take the unit to a recovery expert.
Jan 08, 2014 | HEWLETT-PACKARD Hewlett Packard 146GB SAS...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
I have a r710dell server. It has two 146GB 15K RPM Serial-Attach SCSI 3Gbps 3.5in Hotplug Hard Drives. It seems like only one is being read. Because the C:\ is only 136GB. What could be the issue?
The two drives could be "mirrored" -- everything written onto one drive is also identically written onto the other drive. Thus, if one of the "set" of mirrored drives failed, you just remove the "dead" drive, insert a new drive, and tell it to "rebuild" the "set" of mirrored drives, i.e., it copies everything from the "good" drive onto the "new" drive, and then the "mirroring" will continue.
Dec 17, 2010 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
Raid problem
You can retrive the data but it will not be stable.You should buy 10k drive
Feb 28, 2009 | Dell PowerEdge 1800 Server
New cd rom doesn't work
Have any you added any drives to your computer recently? If so you'll have to check the jumper settings on your drives. If nothing has changed to your computer between the time it was working and when it stopped then you most likely have a dead drive.
But since you say the device manager sees your drive you'll need to go into your administrator tools in the control panel and select computer management. Under storage select drive management. If you see your drive listed but has no drive letter you can right-click the drive and assign a drive letter. The change should be immediate.
Nov 22, 2008 | IBM 300PL (PC 300 PL 733) PC Desktop
Cant create additional raid
if there is a limit this would have been mentioned in the features of the product
please have a check
Aug 01, 2008 | IBM xSeries 226 Server
Dell poweredge 2600 upgrade
Look at the service tag on the unit and go to support.dell.com to get the specs on the exisitng drives. Mine came with Seagate Ultra320 SCSI 80Pin 15K drives, You can shop for the 146GB versions and use your existing caddy's if you would like.
May 27, 2008 | Dell G6632 146 GB SCSI Ultra320 Hard Drive
LACIE Porsche 160GB
What system is the laptop? File differences is the ext-hard drive FAT32 or DOS? Therefore XP [NTFS] is not 'seeing' its content. On the XP machine go to start/Control Panel/Admin tools/computer management/storage/removable storage/and check the file type
Sep 27, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
IBM (73P8023) 146.8 GB Fibre Channel Hard Drive Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
