Question about AOC L24H898-24 LCD TV
My screen is white instead of blue on startup. Some of my inputs are missing from the menu. Can barely see background on pc setting and cannot see tv at all. It's the aoc lh24
5 Suggested Answers
SOURCE: sanyo 32 in. ds32424
check cap around ic101 c256,c253,c252,c258,also c211,c212 &x251 if good replace ic101 la76835n
Posted on Sep 25, 2008
  • 40 Answers
SOURCE: recently when i pull up the TV menu the icons are missing, the background color for the menu panels are blue and my optical audio output is static filled and broken.
Sounds like a software or firmware issue...
Posted on Jun 19, 2009
SOURCE: AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Posted on Nov 30, 2009
  • 11800 Answers
SOURCE: aoc lcd tv color is
Failure of the T-con board - the board that directly controls the lcd panel. The tv is fixable - all you would have to do is to replace the board, just that it's not worth it since a replacement board costs $125 and for $150 you can buy a better brand new tv.
Sell this tv for parts (you can get $40 for it) and just buy a new one.
Posted on Jun 17, 2011
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
Jul 25, 2012 | Westinghouse SK-26H520S 26 in. LCD HDTV
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My comouter screen has changed colour and is barely readable, the startup when it says 'DELL is a white background and orange text anf then when i choose what user i want to go it almost like an...
If it is still under warranty call dell asap. Normally that is the LCD going bad or the video card, which is built in on the motherboard. Usually there is nothing a home user can do with this problem. LCD's are not too hard to change but the Motherboards can be a real bear.
Aug 09, 2009 | Dell Computers & Internet
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
My set has a RED background on all Inputs--DVD,Sat, Recorded DVR.....when playing a DVD a Bright Blue FBI screen is normal and the Bright Green Movie Rating Screen is Normal but the picture is RED....
I found a way to get into the service set-up....press Display, 5 ,volume + and Power.....green numbers come up---could figure out how to go to a Menu-----but somehow the picture is now perfect !
Anybody know why this fixed it......as I said the RED background was on all input screens....the screen with no signal was a solid red instead of Black......
bob
Jun 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
DOES NOT PRINT IN BLACK
This may sound a bit dumb, but believe me as a tech support specialist, I have seen it happen. If you are trying to print a document, what color do you have set for text? I had a lady who wanted the text to be white on blue on the screen in Word and instead of setting it with a blue background and "auto" text, she set the text as white. White print on a white background (paper) doesn't show up...:-)
May 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
AOC L24H898-24 LCD TV Logo
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
