Question about Garmin nuvi 205W GPS Receiver
My screen just went white and a black dot appeared with the message press dot what should i do
  • 343 Answers
Try pressing the dot. If that does not work you can try resetting the unit which will return it to factory specs but all your saved information like favorites and routes will be lost. The reset button is on the bottom of the unit. Power the unit off then press and hold the reset till it starts and the choose yes on the screen to restore the unit.
I have attached a link to the manual which shows a photo of the location and page 13 describes the reset in more detail.
Thanks for using FixYa
http://www8.garmin.com/manuals/nuvi205W_QuickStartManual.pdf
Posted on May 19, 2011
IPad air suddenly went black, except for a dim rotating circle of dots in the center of the screen. It is completely unresponsive. Know any fix we could do?
Put it on to charge. Press and hold the On button and the Home button until the white Apple logo appears and then let go. This is called a Soft Reset.
Dec 11, 2016 | Tablets & eReaders
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a 2005, 42" toshiba LCD model 42DPC85 that when we turn it on everything is good except the whole screen is black but imediatly the colors dot by dot start making the black disappear, it only took...
You need a new DLP chip. The chip has little mirrors that are black on one side and white on the other side. When the chip wears out , your screen will turn white one dot at a time or black one dot at a time or they may just all stick shut at once. Since your screen is black, all your mirrors are closed. You can buy the chip from shopjimmy.com and they have a video of how to replace the chip so you can do it yourself. It takes about 1 1/2 hours. The chip is about $160. To have this service done for you is about $200. Do it yourself and save the money. Your tv will be just like new again. Just make sure the chip is in perfectly level or when you turn your tv back on, your picture will be slanted. you won't notice it on the picture itself but words on the screen or scrolling messages and the menu will be slanted.
Feb 10, 2014 | Toshiba Televison & Video
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
I cannot press H, O and V buttons in post code mode. different li
you will need to do a screen calibration. to do this.
press and HOLD the top left hand corner of the screen while sliding and holding the power switch in the on position. Hold bothe for about a minute and eventually a white screen will appear with a black dot which will say press here touch that dot and the following dots that appear until you get a message saying that calibration is complete.
you should no longer have that problem
Jul 08, 2010 | Garmin nuvi 205 GPS Receiver
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Not starting
sound like your sreen is going out, try MD wireless or any other cell phone repair shop.
Aug 27, 2009 | Cell Phones
Black screen white dots
This is likely due to Hardware Failure. Your GPU (Graphics Processing Unit) has likely overheated to the extent of artifacting which is when the device begins to have trouble rendering objects and images and crashes constantly. The only viable solution is to send it in if you still have warranty, Otherwise, you'll have to either buy a new Xbox 360 or send it in for repairs from microsoft.
Hope this helps.
-Gadorach
Jul 13, 2009 | Microsoft Xbox 360 Console
Garmin nuvi 205W GPS Receiver Logo
410 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
