Question about Janome Memory Craft 10000
Raising feed dogs
My mother is up from Florida and does not have her manual with her for her Janome 10000 embriodery machine. She lowered the feed dogs to do some quilting and it won't raise again? Any tricks that would help? thanks
  • 35 Answers
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
Thread is tangling in the bobbin casing
Hello
The feed dogs should be in the highest position for regular sewing. If the feed dogs are not raised above the plate it will do this. With the machine unthreaded and no fabric.. run the machine to see if the feed dogs are moving and are working.
Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle. ( this machine is fussy about this).
make sure you rethread it exactly as the owners manual shows
Change the needle
Change the thread
Take it in for service
Jul 23, 2011 | Janome Memory Craft 10000
I lowered the feed dogs with the drop feed lever, and now the feed dogs wont come back up.
Flick switch to the UP position.....then....
Turn handwheel one full revolution to reset the feeddog cam
It is on page 26 of your User Manual
Bargain Box
Feb 12, 2011 | Janome Memory Craft 10000
Can the feed dogs be lowered on the 8080?
Open the slide plate and see if you have a lever to drop the teeth down, if you don't then the machine will probably use raised plates.
Mar 06, 2010 | Janome 8080 Computerized Sewing Machine
Can the feed dogs be lowered? And need a manual....
Manuals will be difficult to find because the companies limit themsleves to the amount of spares they make, open the slide plate and see if there is a drop feed lever, if not you may have raised plates instead.
Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Mar 18, 2008 | Janome Memory Craft 10000
How do I raise and lower the feed dog
If you look at the back of the machine you should see the button that will let you lower the feed dog. It looks like you slide the button one way to lower and then the other way to raise the feed dog.
To make it a bit easier just go to the following web site and move down to the pictures as there is one showing the back of the machine. The button would be on your right:
http://www.ebay.com/itm/JANOME-MEMORY-CRAFT-5700-SEWING-EMBROIDERY-MACHINE-QUILTING-TOO-ADDED-EXTRAS-/301088834718
Dec 10, 2007 | Janome Memory Craft 5700
Sewing Machines Logo
169 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
