Question about Kenmore Vacuums
Revolving brush is not turning - Kenmore Vacuums
  • 407 Answers
The belt is broken.Turn the vacuum so you are looking at the brush.That palte needs to come off.Some screw and some just pop on and off.When you have the plate off lift the brush out.The belt fits in a groove on the brush.The other end of the belt fits on a small wheel about 6 inches behind the brush.Put the new belt on and replace the plate.
Posted on May 18, 2011
2 Suggested Answers
  • 20 Answers
SOURCE: Hoover hu 4207/1 pet hair removal turbo brush wont revolve
Try Larryclare1's solution for a Kenmore and see if it helps. Worked wonders for both my turbo brush attachments. http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped
Posted on Feb 27, 2010
Is the brush always supposed to turn, even when upright?
I have a similar Hoover upright and the brush roller continues to revolve even with the handle locked and the hose detached for direct pickup. Seems rather odd to wear out the carpet that way.
Apr 06, 2016 | Hoover U6485900 Bagged Upright Vacuum
Tip
Common generic problem with Dyson upright vacuum brush bar
I see lots of problems with Dyson vacuum cleaner brush bars not revolving, this is normally because the belt has broken, this is an easy and relatively cheap fix. Remove the sole plate normally held by a couple of quarter turn plastic connectors, once the sole plate has been removed the brush bar can be lifted out of it's slotted position, remove the remnants of the old belt. With the new belt manouvre it over the motor spindle first then position brush bar through belt and slot the brush back into its slots and reattach sole plate. This procedure should take no longer than ten minutes even for a total novice.
on Apr 16, 2010 | Vacuums
This is a post from you concerning a Sebo vacuum cleaner."OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on...
First, what is the issue you are experiencing?
You should feel some resistance when turning the beater bar as it is being driven by a fairly tight belt and a motor. The most common issue with the beater bar would be a burning rubber smell. This would mean that the bar was not turning while is was on but in your case it is.
May 08, 2014 | Sebo X4 Bagged Upright Vacuum
Hoover Whole House Bagless Upright. Belt Changed but Brushes arent moving
Take off the bootom plate and remove the brush assembly. Inspect both ends for any hair, string or anything else that might prevent it from revolving. Check to see that the ends are lubricated with some grease, just a bit. It should take care of the problem. The ends should turn easily and smoothly.
Oct 15, 2013 | Hoover Whole House Bagless Upright,...
Brush not revolving
The basic reasons for the brush not turning are as follows
problem with the bearings of the brush roller
problem with the belts
problem with the clutch
Or the vacuum is set to Hard Floors.
I have made a video of how to sort out problems with the bearings, brush, clutch etc
Have a look at my video and if it helps you please leave a comment, testimonial or maybe a box of chocolates :)
If you figure out that you need parts I would encourage you to check out nelsonvacuums or vacuumspot.
Hope this helps
*don't forget to comment*
Nov 29, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Feb 27, 2010 | Vacuums
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
I removed the revolving brush to remove a jammed piece of debris I had picked up and after putting brush back, it no longer revolves
Reattach your belt properly and the beater will function.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Vacuums
BELTLESS BRUSH WILL NOT REVOLVE
I bought my parents the exact same model. Do you have the floor select switch "ON" for the brush? Did the overload protector switch trip? There is a little red button sticking out from the right hand side of the head. Check to see if it is pertruding past the cover. If so, push button in and it should reset.
Feb 05, 2010 | Kenmore 31912 Progressive Direct Drive...
Should the brushes revolve something got caught on the brushes when vacuuming up
Yes, the brushes (beater bar) should revolve. Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Nov 29, 2009 | Electrolux Vacuums
Vacuums Logo
64 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
