Question about Moen 2995 Chateau Three Handle Standard Tub/Shower Chrome
The diverted valve will not turn ,it worked when installed but won't turn now .how do I replace the diverted.
  • 407 Answers
The spout unscrews from the wall.Take that part off and bring it to the store to match it.Then just screw the new one on.
Posted on May 18, 2011
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Pumps out instead of recirculating
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Water won't stay on
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 25, 2013 | Kohler K-14677-BN Loure bath- or...
Fisher and Paykel diverter won't work
The plunger should be out when wax solenoid is hot.
When non energized outputs to drain pipe.
Check to see if it's the right way around.
Oct 27, 2012 | Fisher and Paykel Washing Machines
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Fisher & Paykel GW611 Excellence does not pump water out. All lights are on and when it is suppose to pump, you can hear the noise, but no water coming out of the hose!
It sounds like the drain pump or the diverter valve is restricted. Check to make sure that the drain hose is clear then disconnect power and lay the machine's front on a padded surface to access the drain pump and the diverter valve at the bottom of the tub. Remove the pump's inlet and outlet hoses then check and clear from any debris that may prevent water from draining out. Check the impeller for any damage or restriction.
Check the diverter valve for the same condition as the pump described above. T
he diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Jul 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
When I turn on the tub faucet, water comes out of the spout and shower head. It's a t215.710 model
Does it have a diverter on the spout? If so, replace the spout with the same type. If it is a new installation, did you make up the valve or was it complete and designed for tub & shower? If it's an old valve and it has a separate diverter stem, there is a spacer behind the valve between the valve housing. Replace it.
Apr 21, 2011 | American Standard Plumbing
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Moen 2995 Chateau Three Handle Standard Tub/Shower Chrome Logo
147 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
