Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I have installed my Hunter 44665 thermostat. It produces cold air when the heat is on. Here is how I have it hooked up: Green to G, White to Y/O, Blue to W/B and red to RC1 and jumper to RH and RC/RC1.
  • Hunter Master
  • 43,501 Answers
All you should need to do it to switch the blue and the white wires...
Blue to Y
White to W
heatman101
Posted on May 18, 2011
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
I am converting a White-Rogers 1f89-211 Heat Pump Thermostat to a Hunter 44668/44665 Programmable Themostat. the 211 has 7 wires - blue (C), White (W2),White Jump to E, Black (E), Red (R), Green (G),...
I can't even figure out how to wire that tstat you're better off calling tech support. The jumper doesn't matter but I think your orange should go to y1 and yellow to y/o. I guess one way to figure it out is hook it up turn cooling on and make sure it is cooling. If not you have orange and yellow backwards. I suppose that depends on if the reversing valve energizes in heat or cool. Their manuals are a joke, even for a professional. I recommend calling their tech support.
Jul 03, 2017 | Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I HAVE A HONEYWELL THERMOSTAT THAT HAS BROKEN. IT HAS 7 WIRES. G-GREEN C-BLUE R-RED Y-YELLOW L-BLACK W2/E-WHITE O-ORANGE ITS ELECTRIC WITH NO BATTERY. I BROUGHT A HUNTER THERMOSTAT WITH BATTERY. ALL IT HAS...
Shut power off to Air Handler first before hooking up the thermostat..... Looks like the Hunter Thermostat does not have a Common Terminal...... Is it a Heat Pump thermostat???? I am not a big Fan of Hunter Thermostats they do not have the features that Honeywell thermostats have.
Back to your Question:
G to G ; R to Rc&Rh : O to Y/O; White Wire to W/B; Y to Y1;
L-Black is not used it was for a service lite
C-Blue will not be used it was the common wire
With the Hunter Stat you will not have an emergercy heat option
May 24, 2011 | Heating & Cooling
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
I need to program the 44665 thermostat
enter "hunter 44665" in your internet search box, it should give you several sourced of the manual, both free and for a charge.
Good luck,
Gilshultz
Dec 03, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have a travel trailer with a roof top a/c colman mach111 and I hooked up a thermostate digital. The heat works but cant get a/c to come on. the termanials on hunter thermostate are G W Y RC RH
OK, the wiring that you should have in your RV is as follows: Red White Blue Yellow Green Gray.
This Thermostat will not work on this Air conditioner because the tstat you are installing is a 24V thermostat. The connections are as follows G = Fan, W = White, Y = Cooling, RC = 24V Cool, RH = 24V. The only thing that I can think to do is hook it up like so.
On the G Terminal, Hook up the Green wire from the wall. On W, hook up the White wire, Y, hook up the yellow wire. RC = run a jumper from the RH terminal, RH = hook up the red wire. If this doesn't work then you will have to go back with the coleman thermostat.
Jul 03, 2009 | Heating & Cooling
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
158 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
