Question about AO Smith A O Smith Motors A O Smith 3/4hp 115/230v Ee Square Flange Motor - Qc1072
Hi, I have a QC 1072 A.O. Smith pool pump motor. How to get the impeller off? Which direction does the impeller spin off? Where to but impeller and seal? Thank you very much Greg
  • 106 Answers
The impeller is just screwed on the shaft. COUNTERCLOCKWISE to remove. Some have a screw in the center attaching it to shaft. This is removed by by turning CLOCKWISE.(reverse threads) Remove back cover and secure shaft with a wrench. There are flats on the shaft to hold it. You might need a large pipe wrench to loosen impeller. Wrap with rag so you don't damage impeller.
Posted on May 18, 2011
How to replace seal on a
remove the motor from the wet end of the pump remove the cover on the impeller then remove the impeller screw it it normally backwards thread then spin off the impeller this has a regular thread split the motor from the backing plate then remove the seals and replace with new ones then reverse process
Jul 13, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Can my shaft spin and not my impellor. how can i check
the impeller is usually screw onto the shaft or the shaft has a D (flatspot on one side to lock impeller) so no, the shaft cannot spin without the impeller moving unless the shaft is snapped or impeller is totally stripped (ive never seen either)
if the pump is running but not pushing water, take the wet end off and make sure there is no debris (leaves, worms etc) caught in the impeller fins. you will be amazed at how much that will reduce the performance of a pump
Jun 20, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Marathon wiring
Are you sure? Single phase pool motors are not reversible (unless something weird happened that I can't explain). Three phase motors are reversible, but very rare in residential wiring.
Looking directly at the end of the motor shaft (where the impeller goes) it should spin counter- clockwise. Both of the power wires can be attached to either terminal; there is no "polarity".
Nov 16, 2013 | Hayward 2HP Pool Pump Motor A O Smith...
Reverse direction of electric motor
If your motor runs backwards, you wired the motor backwards. Change your wires around and it will run the correct way.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
How do you detach the impeller from the motor shaft
Lock the end of the shaft opposire the impeller and turn the impeller counter-clockwise as you look at the impeller. Some of them require a little 'convincing' in order to get them to spin.
John
Aug 16, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
AO Smith A O Smith Motors A O Smith 3/4hp 115/230v Ee Square Flange Motor - Qc1072 Logo
306 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
