Question about HTC Wildfire Cell Phone
Few alphabets and the 2nd row on the phone number pad are not working
    Problem Solver:
  • 17 Answers
Firstly clean your cell phone's key pad using Rubber or I.P(cleaner).. If problem does not solved you have to find the line of that numbers and alphabets and have to make jumper on that number........
Posted on May 18, 2011
  • k_krishnakis May 18, 2011
    its a HTC Wildfire touch phone, so no key pad just the virtual keys.......
Find the pattern of missing numbers
57
32 25
17 15 10
9 8 7 3
6 3 5 2 1
Apr 12, 2013 | Computers & Internet
When my number lock is on the letters will not print as stated they will print a number or other
This is normal for a keyboard with embedded number pad, rather than a separate 10-key area. Turn off the number lock to type the alphabetical characters and use the top row of numbers to enter values. Turn on the number lock when entering only a long string of numbers.
Alternatively, connect a USB external keyboard to the notebook. Either get a large keyboard with a separate number pad or get a 10-keypad only (http://www.cyberguys.com/product-details/?productid=37379 ). Then you can have a normal keyboard and stil have the 10-key functions without toggling the NumLock often.
I hope this helps.
Jun 11, 2011 | HP Pavilion DV9620US Notebook
My Samsung Jet s8003 is giving me problems. Frequently when I touch one icon on the bottom of the screen icons say the keypad or phonebook or messages it fails to open. When i open the menu with the middle...
Hi , From the description of ur problem it is very clear that ur touch pad is not synchronizing up with the touch . To fix it u will have to reset the factory settings and u need a a code to do the same . I will give u the code and see if it works .one of these will work for sure
  • *2767*3855#
  • *#5239870*#
  • *#7092463*#
Note : don't forget take a backup of ur contacts and other important things that u can't afford to lose
Nov 09, 2010 | Samsung Jet S8000 Cell Phone
Coby kyros inter tablet/the internet is not in english so icant get on line
How do I change the language back to my original setting?
Go to the Settings Menu. Go to the 2nd row, which is Language and keyboard. Click on that. Click on the first option, which is Select Locale. All languages will then be brought up in alphabetical order.
Oct 29, 2010 | Computers & Internet
The bottom row of my keys and numbers pad won't work
If it is brand new, then you have warranty, I suggest you return it to the supplier to get it fixed, because if you do something to it you might void your warranty.
May 17, 2009 | Dell Latitude D600 Notebook
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
Feb 17, 2009 | Microsoft Excel for PC
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Fn key wont turn off
OK, I've found a soliution! :) I've been diging the internet and many people are having the same problem, so it is a common problem however the soliution is very simple (in my case). The thing is that laptops does not has a saparated Num Pad, and numbers can be found on keys under F1-F12 row or/and (active with Fn key) on alphabetic keys uiopjkl;m/ and so on. But if there is a NumLk key on your keyboard, you can lock the Num Pad on alphabetic keys. Then you have to hold Fn key pressed to write letters.  Find the NumLk key and try to turn off the Num Pad :)
On my laptop (Acer extensa 5120) NumLk key is on F11 and active when Fn is depressed.
Hope this wil help :)
Oct 01, 2008 | Acer Aspire 5100 Notebook
HTC Wildfire Cell Phone Logo
71 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
