Question about GE K ppersbusch 36" Designer Wall Glass Canopy Cooker Hood, KD 957.1
My blanco cooker hood doesn't work. I've removed
Bosch DKE 997E wall cooker hood doesn't work properly
EN Control buttons separating from control mounting bracket. Affected Countries CA, US Affected Appliances HPCN36NS/01, HPCB36NS/01, HPCN48NS/01, HPCB48NS/01 Fault description / Customers complaint / Diagnostic Codes Diagnostic Codes (DC) The following table contains the diagnostic codes, which most commonly occur in connection with the mentioned fault description. Depending on the actual information from the customer, other diagnostic codes are possible. DC Fault description of the customer 160100X45000 Mechanical damage / Holder Root cause On some Thermador Professional hoods with FD 9407 to 9611, the control buttons may separate from the control mounting bracket due to insufficient adhesive between the control mounting bracket and the inside of the hood canopy. Solution Beginning with FD 9612, wider tape was implemented in production. For units built prior to that time, service kit 12022532 is available. The new repair kit includes the control-mounting bracket with wider tape affixed to it, and four screws. The tape will provide more surface coverage to improve the support of the mounting bracket.
Dec 06, 2017 | Bosch DKE93xxUC Stainless Steel Kitchen...
Radiator fan doesn't work
Always keep an eye on your engine temp gauge, find rad thermo switch and bridge connection (it's a switch anyway) this should bring on rad fan. Thermo switch usually on thermostat housing or radiator body housing !
Aug 26, 2012 | 1999 Oldsmobile Silhouette
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
307 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
