Question about Refrigerators
I have a 2001 Kenmore Coldspot that is having temperature issues. The freezer is fine but the fridge will not get below about 55 degrees. I have defrosted it already and also checked the air flow as well. Any ideas what the issue is?
  • Refrigerators Master
  • 8,220 Answers
Is the fan motor blowing from below? Does this model have a damper that opens and closes to allow freezer air into the fresh food compartment? Is the condenser area and kickplate clear of dust and lint?
Posted on May 18, 2011
  • suchef May 18, 2011
    The condenser and kickplate are free of dust and lint. I don't think there is a damper. The fan seems to be blowing normally.
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
I have a Kenmore Elite Coldspot Side - By - Side Refrigerator, Model # 106.55612400 which is nlonger making ice. It does dispense water. My freezer temperature setting shows 0 degrees. Is this the problem...
Check the freezer temperature with a separate fridge thermometer.
It could be a fault with the sensor in the freezer - which can be replaced.
Dec 27, 2010 | Refrigerators
Can you operate a refrigerator in a garage with out problems
Good day,
The high and low temperature range for a domestic refrigerator is 55 and 95 degrees. Above and below that issues will appear.
Above 95 degrees the compressor will be taxed badly, and will obviously shorten it's life.
Below 55 degrees it will not run enough to keep the freezer at decent temperatures, and because it stays off long periods of time, the oil in the compresser sump will thicken, making compressor starting difficult and once again shortening it's life.
It's done all the time but there is a cost long term.
Jul 13, 2010 | Kenmore 73503 Stainless Steel Bottom...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer okay, fridge warm
May need defrosting, so do that, and also unplug the unit for 9 minutes, as this should reset anything that might have affected the problem. Check with Kenmore customer service department on how long the unit takes to get to a set temperature after resetting and consult your manual on your warranty options.
Mar 01, 2008 | Refrigerators
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
